Clips disappeared under hood
Old Apr 15, 2021 | 12:44 PM
interestingstuff's Avatar
Greetings, my car was sitting for a little bit and so I had to open the hood and I noticed the clips that hold this in seem to have disappeared. First question is... What part number are they do I can order them? Is there a best place to get them from? (2009 fit) also... Second question is... Since these seem to have disappeared, is there anything else I should double check to make sure I don't have a similar issue?
Thanks
Clips that holds this in mostly disappeared
Old Apr 15, 2021 | 02:06 PM
fit09's Avatar
I think those push pins are 8mm. Just look on Amazon for a bag of them. Buying those from a Honda dealer is pretty pricey. Should not be any other issues that come to mind. That duct brings air from front of car to back area where air box is located. So don’t just remove it.
Old Apr 15, 2021 | 09:22 PM
howarejew's Avatar
I dunno how much they cost tho.
Old Apr 28, 2021 | 04:04 AM
Rick_a's Avatar
Get a pack of generic ribbed push fasteners at the auto parts store. They're cheap and won't fall out over time. One of them will need shortening.
Old Apr 29, 2021 | 09:31 AM
Alco RS-1's Avatar
Our intake looked like yours. They're Honda P/N 91512-R21-013. I never had any luck finding a suitable substitute at the auto parts stores. With my young driver headed out on a long trip, I gritted my teeth and replaced all 5 Ea, sourcing them from the local Honda dealer at $6/Ea! You'll do better than that on line for sure.
Old Apr 29, 2021 | 11:55 AM
Lr0dy's Avatar
These will fit the bill:
Amazon Amazon
Old May 2, 2021 | 08:06 PM
mxl180's Avatar
Did you happen to change to a bigger battery recently? I did mine and it's been touching the plastic and clips fell out. Anyway I just remove the that air scoop thing for now.
Old May 14, 2021 | 02:27 PM
I swapped out for a bigger battery years ago. I think I put the 51r in if I remember right? There were some issues fitting it in, but it definitely wasn't touching the plastic. I'd recommend trying to figure out how you can fix that and put your scoop back in. There are a lot of posts about fitting in bigger batteries that you can find on here.
Old May 15, 2021 | 02:32 PM
thanks but Alco's P/N number and Lr0dy's link are incorrect for my 09. I just ordered a batch of them and they're the wrong item. They go through the scoop holes but they're too big for the holes in the hood.
Old May 15, 2021 | 05:11 PM
howarejew's Avatar
pull out the pins first then stick it in the hole then push the pins back back in
Old May 15, 2021 | 07:55 PM
cornice6's Avatar
I bought a pack of generic ribbed push fasteners from Amazon since I tend to loose these so easily when taken off.
Old May 16, 2021 | 02:56 PM
Thanks.. That was a logical suggestion, but unfortunately it didn't work. The receiver without the pins are still too big for the holes in the hood. I'll just order different pins.
Fit?
Oct 6, 2023 09:07 PM
endofpage1
Dec 16, 2019 02:35 AM
fanfit
May 13, 2017 11:22 AM
KNPSHIN
Dec 20, 2015 12:41 AM
CrystalFiveMT
Oct 2, 2014 05:09 PM
