UV and/or dry rotted window trim.
Old Apr 23, 2021 | 01:43 PM
Alexander Chernoch's Avatar
Question UV and/or dry rotted window trim.
Hello All,
I have a 2010 Fit Sport MT with ~138,000 Miles and just noticed these trim pieces on my door panels.
Has anyone had to replaced these dry rotted and/or UV damaged wiondow trim pieces. The only option I saw online is to replace the whole door panel and I think that is ridiculous.
Any input on this matter would be greatly appreciated.
This is the best Trim piece on my door. (FL Door)
This on has fallen between the door and window. (FR Door)
You can really see that sun damage and/or dry rot on this piece. (RR Door)
Old Apr 23, 2021 | 03:53 PM
Drew21's Avatar
That is the front and rear "door glass outer weatherstrip." Pgs 20-17 and 20-31 in the 2009-2012 Honda Fit Service Manual.
I am 99% positive you can get this piece from Honda, although I do not know the part number. I suspect if you tell a Honda Dealer Parts Department person the part name (above) they'll be able to get the right pieces for you.
I had the same thing happen on a 2007 Toyota Yaris and was able to buy and replace the weatherstrip easily. It's an easy job. I think the damage sort of sneaks up on you, as I washed the car regularly and never noticed a problem until one day the passenger side was broken off and sucked down alongside the window and the driver side was cracked and separating along the entire length of the window.
Good luck.
Old Apr 23, 2021 | 03:59 PM
Good afternoon Drew,
Thank you for the information I will be calling my local Honda Parts Department and inquire about requisitioning these parts.
I forgot that I downloaded the Service Manual for this vehicle until you mentioned it on this thread.
Have a god weekend and thanks again.
Old Apr 23, 2021 | 04:52 PM
BaySFit's Avatar
You could probably save a lot of money grabbing these from a salvage yard, just about every Fit I see at pick n pull has this part and they’re typically in good condition. The stealership has tried to charge me an arm and a leg for small parts like this in the past. If you don’t want to go to a yard, then maybe get the part number from the dealership then check the price of the part on Hondapartsnow.com, typically their prices are reasonable. Hope this helps!
Old Apr 23, 2021 | 09:51 PM
howarejew's Avatar
Old Apr 29, 2021 | 09:55 AM
Hello All,
Thank you all for posting a reply to this thread the information was very helpful.
I ended up ordering the parts from my local Honda Stealership Parts Department because on HondaPartsNow and they were $30 more in total.
Old Apr 30, 2021 | 02:09 PM
Just an FYI for anyone who needs to have these replaced, there is a backorder for PN:72910-TF0-003 and they do not have a date for when Honda will have them again.
I just learned of this a second ago when I called Honda to see when the parts will arrive and the Salesman informed me the wrong PN's were ordered last week.
Old Aug 6, 2021 | 01:56 PM
Hello All,
Just an update to this thread.
My parts finally came in July 27th, I has been almost three months since I ordered the parts.
Thanks to everyone who provided helpful info and feedback on the matter.
Best Regards,
Alexander
Old Aug 7, 2021 | 06:23 PM
Pyts's Avatar
Thanks for all the info! I'd love to replace mine when I get some cash to play with.
Old Jun 5, 2024 | 10:34 AM
FLFit2010's Avatar
Hi there,
I have the same issue and I am looking to replace the dry rotted weatherstrip from my 2010 Sport.
I'm having trouble trying to decipher if the part is Honda 72950-TF0-003 or Honda 72910-TF0-003? Or do both parts need to be purchased to replace the weatherstrip?
Links to the parts:
https://www.hondapartsnow.com/genuin...205AT&filter=()
https://www.hondapartsnow.com/genuin...ctor,4237773,9
Thank you in advanced for the assistance.
Old Jun 5, 2024 | 11:10 AM
Originally Posted by FLFit2010
Hi there,
Links to the parts:
This depends if your replacing the drivers side or passenger side. 72910 should be the Passenger side part number.
Old Jun 5, 2024 | 12:22 PM
FLFit2010's Avatar
Thank you for the response. Yes, it's the rear door on the passenger side.
The diagram on Hondapartsnow, has #11( 72950-TF0-003) and #9 (72910-TF0-003) in the same region, so I have been trying to figure out which is the correct part to purchase to replace.
Sounds like #9 (72910-TF0-003) is for the rear passenger side, and #11 is for the rear driver side?
I noticed in another thread they used
72950-TF0-003 (Molding Assy., L. RR. Door)
https://www.fitfreak.net/forums/fit-...rip-seals.html
Which is why I'm a bit confused which part I need.
Old Jun 5, 2024 | 12:38 PM
I noticed in another thread they used 72950-TF0-003 (Molding Assy., L. RR. Door)
On the part description the “L” indicates the driver side or left side; the other part had “R” instead.
Old Jun 5, 2024 | 12:45 PM
FLFit2010's Avatar
Ah! Thank you so much! I was going crazy trying to figure out the difference.
I appreciate the help with clearing up my confusion and teaching me how to understand the part description correctly.
Old Jun 5, 2024 | 12:49 PM
Anytime!
One of the best features of joining a forum is that people usually try and to educate/help whenever they can.
Old Jun 20, 2024 | 06:53 PM
MPGASAP's Avatar
This is from my maintenance log from when I replace mine:
"Replaced all window molding assemblies: R Front 72410-TF0-003, R Rear Door 72910-TF0-003, L Front Door 72450-TF0-003, L Rear Door 72950-TF0-003"
Mayumi
Sep 21, 2025 01:50 PM
gfrobe
Nov 13, 2016 08:43 AM
Tenuki Kyle Gray
Sep 13, 2016 01:55 PM
Ursenay
Nov 3, 2012 12:39 PM
wackyflik
Sep 2, 2012 08:28 AM
