Ignition won't turn on
Old Sep 13, 2021 | 06:26 PM
Zardiw's Avatar
Key won't turn the ignition anymore. It started with the key being harder to push in.....got worse quickly......now key won't turn ignition.
Any ideas?
Have a new ignition switch assembly on order....... $750 .....insane.......
z
Old Sep 14, 2021 | 12:03 AM
claycolvin's Avatar
Ignition
Try lubricating the key mechanism first. Don't spray too much lube into the key assembly and get oil all over the electronics in the steering column. Best of luck. Clay
Old Sep 15, 2021 | 09:48 PM
Pyts's Avatar
A worn out key, my good sir, could cause your problem. You can purchase one from College Hills Honda for, I believe, $60. Then a programming may set you back another 50. You may also be able to buy a blank key and transfer the computer chip from inside of the original. Some graphite lubricant (i think graphite is what's recommended. I believe it's supposed to be dry) may serve to get your key in and out while awaiting a replacement.
​​​​​​I'd recommend not using/forcing a key that is binding unless it's truly necessary. Could lead to damaging the ignition switch which, as you mentioned, is much more expensive.
Old May 28, 2022 | 11:16 PM
56chevydan's Avatar
Oops! The post I made here was meant for Mr Coffee's current posting- not to revive this older posting..
Bluecrayon
Apr 6, 2021 01:14 AM
HighMileage07
Jul 20, 2020 10:16 PM
soboyle
May 24, 2020 04:03 PM
Fitgirl99
Dec 11, 2015 04:10 PM
jeff_1986
Oct 30, 2011 06:26 PM
