High oil usage
Old Nov 17, 2021 | 08:57 PM
Fitnjammin's Avatar
High oil usage
2010 1.5l Stick shift, 207000 miles. Engine gets through oil fast. Bought it new. 30.1 mpg. Don’t see any smoke. What could be causing the high oil unsafe? The PCV valve is old and stuck. I’m not as concerned about the oul usage as I am about the catalytic converter burning out. Thanks for any input
Old Nov 17, 2021 | 11:31 PM
Can_It_Fit's Avatar
How fast is fast?
Old Nov 27, 2021 | 03:31 PM
Fitnjammin's Avatar
About a quart every 500 miles
Old Nov 27, 2021 | 06:27 PM
steve37's Avatar
30.1 mpg is very low for a m/t. You should get high 30's to low 40's.
Old Nov 28, 2021 | 07:39 PM
Pyts's Avatar
Mileage can only be so good when you're burning at minimum 6 quarts through a 4 quart engine between oil changes.
An oil catch can with a good breather on it could alleviate some crankcase pressure pushing oil through your pcv back into your intake, but your problem sounds serious, particularly if you havent noticed a leak..
​​​​​ I think your engine needs the full work-over.
Old Jan 27, 2022 | 02:27 PM
tbearfit's Avatar
Old thread but have you replaced the PCV?
Vince_TB
Apr 25, 2014 11:58 AM
Sylak
May 14, 2010 03:41 PM
mozarwasagenius
Mar 31, 2009 12:54 PM
sonicsc1
May 10, 2008 08:32 PM
db_et_ac
May 24, 2007 09:42 PM
