Rev hang
Old Feb 4, 2022 | 01:44 PM
steve37's Avatar
Originally Posted by TnTkr
I once specifically asked that question in this forum and was told that a throttle controller cannot remove the (annoying) rev hang, because it is not part of the throttle communication but coded in the engine management. If you have solid information that it is otherwise, I'd be very keen to get such throttle controller.
https://www.sprintboostersales.com/B...ve-By-Wire.cfm
The first thing I noticed after buying my Fit was the 'rev hang'
After using the 'Sprint', I don't even notice it anymore. Maybe part of that is just getting used to it, but I'm sure it's less than it was before the 'Sprint'
Old Feb 4, 2022 | 10:43 PM
GrE8_Fit's Avatar
Apparently you can take quite a bit of weight off the stock flywheel, too. That'd really help (on a M/T).
Old Feb 7, 2022 | 11:12 AM
Btim's Avatar
I find the "rev-hang" helpful on my 2012 MT. Makes it less likely to have the mismatch in RPM for the next gear when upshifting. I thought it was designed for this purpose.
Old Feb 7, 2022 | 01:56 PM
steve37's Avatar
^^^ Maybe for down-shifting...but up-shifting it is irritating.
Old Feb 7, 2022 | 02:08 PM
RD36's Avatar
I find that if you eliminate some wheel hop it helps also putting the power down to the wheels. I recommend the Hassport rear engine mount and brace in the back and front. I got the hard race rear brace and this seems steady her up. Make the car stable and helps put the power to the ground lol.
ALSO swap you clutch master cylinder with a older civic which doesn't have delay valve. That will make it shift like an old school honda.
Cmos
Feb 4, 2022 06:56 AM
Honzo
Mar 5, 2016 05:18 PM
BlueAngelFit
Jan 31, 2014 12:08 PM
Remould
May 29, 2012 11:39 PM
Pat272
Apr 7, 2007 04:01 PM
