Should I replace my headlight plug? Photos included.
Old May 9, 2022 | 11:57 AM
Idir Mahrouche's Avatar
Hello,
This is the state of my headlight plug. It’s intermittent. I kinda have to take the headlight off and replug it just for good connection.
I think it’s evident the issue is in the plug right?
Old May 9, 2022 | 01:01 PM
56chevydan's Avatar
If a wrecking yard or a Honda dealer can provide a replacement electrical socket, I'd replace it. Either way, you need to buy some dialectric grease from an auto parts store and coat the terminals before you plug it into the headlight again. If you're going to use your existing plug, or another used one, you first need to use a small wire brush to clean the electrical contacts before you apply the grease.
You don't show a factory rubber boot in your pics. Do you have one that slides over the plug to protect it after installation?
Old May 9, 2022 | 01:04 PM
I do have the rubber. I just took it off to check if was the bulb that was misbehaving. I’ll go with the second option. Restoring my plugs. Thanks a lot.
Bigaizsosexy
Jul 14, 2023 01:28 AM
Idir Mahrouche
Apr 22, 2022 05:59 PM
GD3 GeGe~
May 29, 2020 02:17 PM
BigSpark
Mar 17, 2020 08:43 PM
HONDAMATIC
Apr 14, 2010 11:39 PM
