Using 1gen shocks on a 2gen
Old May 21, 2022 | 05:05 PM
4t5's Avatar
4t5
Swapping 1gen struts on to a 2gen when lowering
Hello i just wanted to share that i swapped 1gen strut on to my 2gen because i wanted shorter struts in the back to remove the slack from my lowering springs.
I bought lowering springs but didnt get the low i wanted, so i wanted to cut them but that would leave the spring suuuper loose as you can see in one of the pictures.
So i searched around for some adjustable struts with no luck. then i looked at 1gen struts and to my suprise they were 100mm shorter!
i bought them and when they arrived i cut my springs to the low i wanted, and when u put them in they had around 90mm slack so the 100mm shorter struts were perfect!
also made some new rubber mats for the springs to sit on as they are wider in diameter at the bottom after the chop
also yes i know the springs are upside down but that just worked out better
2gen strut left, 1gen strut right
chopped spring with 2gen struts
video of 1gen struts and chopped springs
how it sits after the chop
how it sat before the chop
also threw on new wheels
tk9985
3rd Generation GK Specific Suspension & Brakes Sub-Forum
13
Jan 22, 2021 02:27 AM
jaxbeach
Nov 29, 2020 05:29 PM
lowkeymods
May 4, 2011 12:34 AM
Fit_Noob
Apr 9, 2008 01:09 PM
Darkstars
Mar 25, 2008 07:55 PM
