Is battery housing necessary?
Old Jul 13, 2022 | 11:22 AM
Ciaran84's Avatar
I'm replacing the battery in a 2011 Fit. The new battery has a weird plastic trim that sticks out along the bottom (along both long sides) and means the battery won't fit in the plastic housing. Can I just remove the housing? I checked and the battery fits fine and feels fully secure without it, but I want to check if this will cause me problems or is otherwise a bad idea. TIA!
Edit: here's a stock picture of the battery so you can see what I mean.
Here's how it looks in there with no housing:
Old Jul 14, 2022 | 06:18 PM
JHMGE8H34DC's Avatar
You'll be fine without the plastic tray. The only real purpose it serves is to contain any fluid that might happen to spill out from a traditional lead acid battery. Since your battery is Sealed Maintenance Free (SMF), that's not a concern. If your battery leaks, you've got much bigger issues than the flimsy plastic tray containing it.
Old Jul 16, 2022 | 01:12 PM
Ciaran84's Avatar
Great, thanks!
Jensen Healy
Dec 6, 2019 02:54 PM
ChuckDustin
Mar 29, 2019 09:11 PM
littleblackcar
Apr 22, 2016 12:12 PM
CitoFit
68
Jun 18, 2015 10:38 AM
pzriddle
Jan 23, 2015 06:31 PM
