08 starting issue.
Old Nov 9, 2022 | 10:21 AM
mybrothersfit's Avatar
08 starting issue.
So our 08 fit cranks but won’t start. I’ve heard crank and cam sensors can cause this. But also the key. There’s this green key light on the dash. It turns on with the key but it goes off when cranking. Is that normal? Never paid attention to it before. Thank you.
Old Nov 9, 2022 | 06:31 PM
56chevydan's Avatar
When you turn the ignition switch on without cranking it, can you hear the electric fuel pump come on and hum? If not, check your fuel pump fuse. On a Gen 2 Fit, it's fuse 20. On a Gen 1 Fit, I'm not sure what number it is. There should be a fuse label/decal under the pass. side of the dash that id's the fuses. Good luck.
Old Nov 9, 2022 | 06:41 PM
The pump does come on. And when I crank it for a bit I can smell the unburnt fuel. Thank you.
Old Nov 10, 2022 | 06:35 PM
Pyts's Avatar
​​​​​​Fast and free: try starting it with the gas pedal floored.
also, how much fuel do you have in the tank?
@56chevydan What do you think the odds are?
Also, sorry I didn't respond in the previous thread. I really appreciated the kind words, man.
JonStewartMill
May 12, 2022 05:20 PM
CurlyHairedGirl
Aug 2, 2017 03:04 PM
cranky18
Feb 20, 2009 09:10 PM
lmatthew9
Sep 20, 2008 12:16 AM
yeamans17
Dec 13, 2007 11:25 AM
