08 Fit - key won't turn in ignition
Old May 12, 2022 | 02:56 PM
JonStewartMill's Avatar
My friend has a 2008 Fit that won't start. Apparently the ignition switch - or an interlock somewhere - is the issue, because it's impossible to turn the key even when applying the brake. As a result (I think) it's impossible to shift the car out of park, so we can't push it to a more convenient spot.
Is there a way to overcome the ignition lock so the key will turn? Or a way to overcome the transmission interlock so the car can be shifted into neutral?
Thanks
Edit: my friend reports that he can now turn the key in the ignition, but still can't get the transmission out of park.
Old May 12, 2022 | 04:48 PM
Frenzal's Avatar
There should be a slot near the transmission lever that you can insert something to bypass the interlock.
Something like this (but this is for a '15):
Old May 12, 2022 | 05:20 PM
That's what I was looking for. Thanks.
Zardiw
May 28, 2022 11:16 PM
Bluecrayon
Apr 6, 2021 01:14 AM
HighMileage07
Jul 20, 2020 10:16 PM
jeff_1986
Oct 30, 2011 06:26 PM
chloeishere
Nov 23, 2009 12:41 PM
