Sticky Key
Old Feb 20, 2009 | 09:56 AM
cranky18's Avatar
Sticky Key
I went to pull the Fit into the garage last night and the key was difficult to get into the ignition. It is also difficult to remove now. This just started happening. I did not get a chance to to try the other key to see if it does the same. Has anyone heard of such a thing?
Old Feb 20, 2009 | 12:23 PM
1FiTpINOY's Avatar
The only thing I can suggest is to remember that you have to push the key in for the first click. Starting from the key and engine on:
Turn back one click (engine turns off)
Push in, then turn back, last click
Pull out key
Lawlz if not that then try your spare?
:P
Old Feb 20, 2009 | 12:25 PM
BakedCookies's Avatar
Have you bent it? Maybe in your pocket?
Old Feb 20, 2009 | 01:15 PM
cranky18's Avatar
Aha! I just looked at it and there is an ever so slight bend towards the end. I looked at it last night but I guess since it was dark it was not as noticeable, I didn't think twice. Wow, it doesn't take much.
Old Feb 20, 2009 | 06:52 PM
jimrb66's Avatar
sticky key
Hi Give the key a quick squirt of wd-40 or a quick spray into key-hole.work ignition a few times.
Jimrb66
Old Feb 20, 2009 | 08:52 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
this is exactly why I'm going with the flip out key fob.
plus its just annoying in your pocket.
Old Feb 20, 2009 | 09:10 PM
cranky18's Avatar
Straightening the key out fixed the problem. I did not think of it being bent because I do not normally carry my keys in my pocket. My engineer at work thinks I tried to pull the key out to fast from the ignition and bent them.
He cannot prove that!
RixAE86
Feb 21, 2019 01:43 PM
Fr8Dog
Jan 14, 2019 11:48 AM
Echeng1965
Apr 27, 2016 03:03 AM
jeff_1986
Oct 30, 2011 06:26 PM
chloeishere
Nov 23, 2009 12:41 PM
