AC not working
Old Jul 27, 2023 | 11:29 PM
Red.velvet.ghost's Avatar
AC not working
Hey guys
I have a 2010 Honda fit base
I bought it 2 years ago and the AC stopped working after 2 months.
In August 2021 the AC compressor died completely, so I changed it
The AC isn't working still but I ran a wire from my relay box to my battery and then it was working
I don't want to be using this method because of the obvious dangerousness of this
Does anyone had or has this issue and figured it out ???
Old Jul 28, 2023 | 05:45 AM
mykizism's Avatar
Originally Posted by Red.velvet.ghost
Hey guys
So when you bypass the relay the AC works.. it seems like it would be an electrical issue. Have you tried replacing the relay to test if that fixes the issue? From your statements it appears the the AC system "works" rather it is a power delivery issue or a wire or connection is faulty.
Old Jul 28, 2023 | 07:42 AM
I tried another relay and it did not work. Maybe this relay was also bad... Other than that relays what could be the issue ???
Old Jul 28, 2023 | 08:36 PM
mykizism's Avatar
It could be another bad relay or the relay is not getting power at all meaning the original relay could be fine.. and it is not getting power. That is something you will need to determine by doing some testing.
fsaussies
Sep 20, 2022 07:38 PM
Mickeynol
Aug 3, 2022 10:44 AM
The Kev Master
Jun 23, 2022 10:38 AM
Grant Wertheim
Jun 17, 2020 03:50 PM
redludesh
Jul 22, 2018 02:20 PM
