Added DRL button
Old Aug 14, 2023 | 01:06 PM
Maurtis's Avatar
Added DRL button
A couple months ago I installed some drop-in LED headlight bulbs. The brightness is great, BUT... the DRLs are way too bright. For DRLs, it seems they just send less wattage to the high beams, but since the LEDs use less wattage anyway they are just always on full brightness when DRLs are activated. During full sunlight during the day this is not too big of an issue, but if you ever want to just sit in your car at night with the AC on (say, waiting for a friend), you are either blinding anyone walking by or have to shut off the car and turn it back on to reset the DRLs.
I was originally going to just pull the 7.5A DRL fuse, but I do like having the option of having them on during the day for safety/visibility. So instead I bought a DRL button and a fused fuse tap.
I purchased a DRL button that fits the Fit on AliExpress and a
fuse tap (with fuse) fuse tap (with fuse)
to replace the DRL fuse. Combining those two allows me to switch the DRLs on or off at will. I did not wire up the little LED on the button since it is over 100 degrees outside during the day and I was being lazy, LOL.
I finally have a button here instead of all blanks!
Two separate components
Attached with copper crimp sleeves and covered with heat shrink. I briefly contemplated soldering the wires, but once again laziness won the day.
Old Aug 15, 2023 | 09:20 AM
Bowbridge's Avatar
Nice job, may give it a try.
Old Aug 15, 2023 | 09:28 AM
NWCH's Avatar
Or just turn your headlights on when you turn the car on. This is also what the parking light function is for. Having your lights on, without your bright headlights being on.
This is a completely pointless mod.
Old Aug 15, 2023 | 09:48 AM
dosbirn's Avatar
Your comment is completely pointless. Move on if you’re not interested. Nobody really cares what you think.
Old Aug 15, 2023 | 10:30 AM
Maurtis's Avatar
$13 in parts and 15 minutes of time and I now have the option to park in the dark as well as not having my touch screen dimmed during the day from running headlights.
Worth it to me, but not to you. No worries.
Old Aug 15, 2023 | 10:31 AM
zcargo's Avatar
You can also set your parking brake before starting the car and the DRLs won't turn on until you release the parking brake. Of course, if you arrive somewhere and want your DRLs to be off, it requires you to turn off the engine, set parking brake then restart car.
This feature also helps if you have a weak battery and want to lessen the electrical load while starting your car.
Mark
Old Aug 15, 2023 | 08:29 PM
NWCH's Avatar
You obviously care enough about what I think to quote and repost it again for no reason. lol
DadDadDad
May 6, 2022 08:52 PM
metal
Nov 5, 2019 06:18 PM
FitBiscuit
Sep 21, 2017 07:57 AM
justalilbit
May 5, 2017 01:58 PM
esnave09
Nov 16, 2015 11:29 PM
