2011 fit wont start with New battery
Old Dec 1, 2023 | 09:07 PM
Avrin's Avatar
Turns over 1-2 times sounds like it wheezes... Checked Connections, they look ok....What do I look at next?
Thanks!
Old Dec 1, 2023 | 10:48 PM
JDFit's Avatar
Is the new battery charged?
Old Dec 2, 2023 | 11:11 AM
Frenzal's Avatar
Good ground connections.
Old Dec 2, 2023 | 06:26 PM
Avrin's Avatar
Yup just checked, battery fully charged. I have checked fuses, and grounds, all look good.
Old Dec 3, 2023 | 09:21 AM
Pyts's Avatar
post up voltage readings from before and after trying to start to isolate whether you have fault in your battery or if your alternator is leaving you with a low charge. if the battery is starting at and staying at good voltage (12.6) and connections are good, then check for codes, begin considering starter replacement/issues.
​​​​​​slow/few cranks is starter/battery stuff.
Old Dec 3, 2023 | 08:16 PM
Avrin's Avatar
battery is 12.3 and when turned over goes down to 7.4 (2 slow turns then stops) after battery still reads 12.3. Going to get a tester for codes tomorrow.
Old Dec 3, 2023 | 10:47 PM
Pyts's Avatar
Sounds like your new battery isn't up to snuff. Maybe not bad, but perhaps not rated for starting our little engines/defective? Is it properly sized with cold cranking amps n what not? 370cca or around there?
Did you... get a funny battery?
Ciaran84
Jul 16, 2022 01:12 PM
CitoFit
68
Jun 18, 2015 10:38 AM
pzriddle
Jan 23, 2015 06:31 PM
OtterKin
Jan 3, 2014 05:27 PM
ezesynergy
Oct 31, 2011 10:18 PM
