Identify This Oil Leak
Old Jan 22, 2024 | 11:41 AM
Pyts's Avatar
Be sure to post up pictures! And.. sorry we couldn't point to a more specific location.
If it's not the valve cover, I would consider hoses connected to the intake plenum as strong possibilities. Oh. you could do the PCV hose pinch test. I'll try to find the thread about it.. it's not likely your leak (still possible) but it may tell you the cause of your leak!
Edit: Here's the thread link for pcv location
Old Jan 22, 2024 | 12:53 PM
Frenzal's Avatar
Originally Posted by Mister Coffee
@zcargo Thanks, Mark. The AC appears to be working normally.
Next step might be to lift the car and start taking things off: wheel, wheel well liner, every cowl that's blocking the view, etc. A pain in the neck I'm not up for this week, but maybe soon.
Or clean it up good and see if and how fast it comes back. Could save you a lot of work!
Old Jan 23, 2024 | 09:54 AM
Alfa38's Avatar
^^^ this. First clean it and just watch for a while.
Old Jan 23, 2024 | 12:15 PM
Mister Coffee's Avatar
Absolutely. I'll have to take some stuff off just to do the clean up, but that's obviously the way to go.
Old Jan 23, 2024 | 12:17 PM
Thanks, Pyts. I remember that thread and those pictures. But the PVC valve is just not near where this leak is.
Old Jan 24, 2024 | 09:55 AM
Outfit's Avatar
I don't think anyone has mentioned the dipstick tube. It's right above the oil filter where some oil is apparent. A possible reason it looks cleaner than the grime on the bottom of the engine is that the oil is transporting grime down to low points where it collects and dries. If you see evidence of oil pushing around the dipstick tube, the o-ring may be leaking, or your PCV system may be unhappy and raising crankcase pressure.
Don V.
Old Jan 24, 2024 | 10:06 AM
Outfit's Avatar
Can I have another guess? I'm on a roll today
It is possible during the prior oil change the oil filter gasket may not have seated completely to the crankcase and allowed oil to weep. Maybe all you need is to clean the old mess, and install/tighten a new name brand oil filter, fill 'er with oil and maybe life will be Fit goodness again.
Don V.
Old Jan 24, 2024 | 12:11 PM
@Outfit Thanks, Don. I haven't noticed problems with the oil filter or the dipstick, but I will keep those in mind as possible sources of the leak.
Tomnkc
Sep 24, 2024 04:33 PM
AGoines
Dec 6, 2023 09:37 AM
EVO
Jun 29, 2023 03:08 PM
Mister Coffee
Oct 31, 2022 08:44 PM
Scotty2h
Aug 27, 2015 06:19 PM
