T25 turbo build question
Old Feb 20, 2024 | 05:37 PM
upovejon's Avatar
Hey I’m getting parts together for a t25 turbo build. I have the turbo and intercooler selected and I’m going to pull 410 injectors from an Acura, but what kind of fuel pump do I need? Thank you for the time in advance.
Old Feb 20, 2024 | 05:39 PM
upovejon's Avatar
It’s a jdm model with a Japanese vin if that matters
Old Feb 22, 2024 | 11:38 AM
Stubborn Rash's Avatar
Look up “Honda Fit Turbo Kit Install” on YouTube. Unequal Fabrication is the company and they have a website. He uses a jumper harness to adapt the 410cc injectors to the Fit wiring harness, and he uses a Mitsubishi EVO-10 fuel pump which supposedly works in the Fit fuel sending unit. I’d contact Unequal Fabrication for details. I’m certainly no expert, I just remember running across the video and figured I’d point you in the direction of someone who knows what he’s doing. Good luck.
Old Feb 29, 2024 | 07:33 AM
MarenDawson's Avatar
Thanks for the advice, I will check his channel.
Old Mar 1, 2024 | 12:10 AM
You’re welcome. Be sure and post pics of your build. Sounds interesting.
Old Mar 11, 2024 | 07:53 AM
Sure. I will
Old Aug 9, 2024 | 10:29 AM
slimchriz's Avatar
I'm running a Deatschwerks 255lph pump which is better but the thing you need to know is this system uses an in tank regulator.
Meaning you can and will pump more fuel with a upgraded pump but with your pressure capped in the tank there is a very real limit to the amount of fuel you can deliver.
You may be able to get better performance by switched to a return line system where you use a boost referenced adjustable fuel regulator up front.
Otherwise you may notice leaning on the top end no matter how much pump you use.
Im running a modified Sprintex SC with the 410cc RDX injectors and was having to max out the injectors to keep up, moved to a smaller pulley so Return-line system is in works.
cte8624
Jan 4, 2014 09:42 PM
porkchop
Mar 1, 2009 04:16 PM
tonyd3773
Jul 26, 2008 03:43 PM
tonyd3773
Mar 12, 2008 04:40 PM
southwilrise87
17
May 21, 2006 10:37 AM
