I have no idea what Jose this goes to but it seems to be leaking.
Old Oct 26, 2024 | 06:02 PM
Princeofpeas's Avatar
I have no idea what hose this goes to but it seems to be leaking.
Middle right hose
Black dried up crust around the hose
Old Oct 27, 2024 | 03:07 PM
jajehalbig's Avatar
That looks like a breather tube for the transmission. It doesn't look like it's leaking. Which is good because it shouldn't.
It does look dirty.
I would clean it, without making any potential clogging worse.
I ended up cleaning mine. And then cut the tube slightly shorter, because I accidentally got crud in it. I did this while replacing the in-line transmission filter.
Old Nov 1, 2024 | 02:21 AM
Pyts's Avatar
I agree with the above poster. It's the trans breather, and replacing the filter may help with a pressure problem. Bit of a chore. Before that, I'd check the fill level of the trans. If it's overfilled, you've got your answer. If you're unsure as to whether the fluid has ever been changed, but feel inclined to change it, I'd recommend considering a fluid from redlineoil. Their fluid viscosities tend to be a little heavy, but they seem to do a dang fine job preventing the problems that come from changing fluid for the first time, late in the game.
I've had success, anyways.
Shelb
Mar 10, 2024 12:57 AM
Shelb
Mar 9, 2024 09:45 PM
mj4521
Jul 30, 2019 02:56 PM
pokems23
Aug 2, 2014 09:36 PM
breadman
Mar 23, 2011 07:57 AM
