Rattling noise, replaced everything that touches the serpentine belt
Old Feb 12, 2025 | 01:23 PM
mikel1993's Avatar
Hi everyone, I have been trying to fiix this awful noise that I hear whenever Im between 1.5 and 2k rpms. I was positive it was from something to do with the belt drive, but I have now replaced the AC clutch, alternator, water pump, and belt tensioner. The noise is still there 🥲
What else could be the culprit??
I'm attaching a video from before I replaced everything, but the noise is still the same.
https://youtu.be/MxS3alR5y4s?si=_E3oDelKrFNbOy6E
Old Feb 14, 2025 | 11:15 PM
Pyts's Avatar
That's a tough one. it's that high-speed ringing-like drone I'm hearing, yeah? Kind of like a sped up dial tone in a phone call?
The serpentine belt is a reasonable culprit -- there's some little bearings spinning pretty fast. The best thing I could advise for this is to pick up some 1/8" or so vacuum hose, 2-3' worth, and stick one end in your ear, using the other in hand to help isolate the sound source.
One of the common rattles this car has presented for others is that of the exhaust heat shield. If I'm picking out the right noise, I could see its potentially being caused by a washer or what have you vibrating against some thin, rigid metal.
But that old ear-hose trick, as silly as it seems, has served me well for many a diagnosis.
Old Feb 26, 2025 | 12:30 PM
mikel1993's Avatar
Thanks for the response! I did a valve adjustment, torqued my spark plugs, nothing.
Then I checked the heat shields!!! Loose bolt! Problem solved 🥲 at least all of my components are refreshed
Insane the amount of work I did for such a simple fix
Old Feb 26, 2025 | 12:39 PM
Frenzal's Avatar
I almost told you about the heat shield, but thought it wasn't that per your description.
Should have done it!
Glad you found it out!
flyingby
Mar 5, 2025 10:45 PM
kimapz
Dec 8, 2021 07:11 PM
tyrtill
Jul 31, 2018 08:25 PM
3cg
Mar 24, 2015 06:35 AM
apexanimal
Nov 9, 2013 08:11 PM
