interesting facts: little stuff.
Old Dec 13, 2008 | 10:31 PM
  #121
skygunnerblue's Avatar
Originally Posted by noxikon
There is a Gas Cap holder (the molded U-shape), on the inside of the Fuel door.
I was pleasantly surprised when I first discovered this.
Old Dec 14, 2008 | 11:21 AM
  #122
niko3257's Avatar
FitFreak GE8 DIY Guy
i wasn't cause my previous car had one.
but i was surprised that it works very well.
my other car didn't work for nothing.
Old Dec 14, 2008 | 06:00 PM
  #123
czarny's Avatar
Behind the two cup holders located under the radio is a slot that fits cd cases perfectly. Not sure if that was mentioned yet or not (hopefully not).
Old Dec 14, 2008 | 07:50 PM
  #124
KatzeChicX's Avatar
After all the complaints about the cupholders in the front part of the middle console, I just wanted to note that I finally understand why they have the funky shape...
it is to fit a coffee cup with a handle!
Maybe this is a no-brainer for others, but for me--I had no idea.
Who makes their own coffee anymore anyway? J/k. I had hot chocolate in one of those thermal mugs with a handle...
Old Dec 14, 2008 | 11:35 PM
  #125
Tork's Avatar
If you click your lock button twice on the fob and your horn does not beep, you have a door/hatch open or not fully latched.
LOL no beep walked back to the car with my 7 year old and I said "sweety, you have to push the door shut!" she left it open about 2 inches
Old Dec 14, 2008 | 11:51 PM
  #126
Drewski's Avatar
Also an Air Spencer fits in there like a friggin' glove. Kek.
Old Dec 15, 2008 | 08:26 AM
  #127
Blackout's Avatar
if someone could try this on a 09 fit (im out of town and tell me if this works (my dads FORD did this) (dont know y?)
TO TURN OFF THE BEEPING NOISE WHEN THE PASSANGER DOES NOT WEAR THE SEATBELT:
1) IN LESS THAN 1 SEC. WILE THE CAR IS RUNNING LACH AND UNLACH THE SEATBELT 9 TIMES
2) ON THE 9TH TIME KEEP IT UNLACHED AND WHEN SOMEBODY SITDOWN AND DOES NOT PUT ON A SEATBELT IT WONT BEEP THIS WELL RESET ONCE THE CAR IS OFF
SO DID IT WORK?
Old Dec 15, 2008 | 11:03 AM
  #128
mole177's Avatar
^ you gotta be pretty fast to do that.
Old Dec 15, 2008 | 11:29 AM
  #129
Virtual's Avatar
lol. So true. In less that 1 sec.
Old Dec 15, 2008 | 12:38 PM
  #130
pbanders's Avatar
The Sport A/T "+" paddle shifter has two ridges on the back of it that aren't on the "-" paddle, to distinguish it by touch when you're shuffle steering and want to shift up or down.
Old Dec 15, 2008 | 01:08 PM
  #131
M4psycho's Avatar
is that even humanly possible? lmao
Old Dec 16, 2008 | 01:53 PM
  #132
Blackout's Avatar
ok my bad i ment to say 10 sec but still as fast as possable with the lach held down so it can go in and out with ease sorry about the mix up
Old Dec 16, 2008 | 03:43 PM
  #133
skyghene's Avatar
SO DID IT WORK?
So if I'm reading this right you have to latch and unlatch the seat belt 9 times every time you start the car if you don't want the warning to go off? I don't like my car telling me to put on a seat belt, but that's too much work. I'm sure someone will eventually find a fuse or something you can disconnect to turn that off.
Old Dec 16, 2008 | 04:11 PM
  #134
jrlnc's Avatar
Question Rear hatch oddity
I've had my '09 for just 3 days now and have noticed this (coming from an '07 Fit).
When the hatch is open/up and I'm ready to close it . . . I reach up on the right side to pull it down and I notice . . .
The grab handle is upside down/backwards!
It is mounted the opposite way from my previous Fit. Or was the 2007 Fit handle wrong? This one feels uncomfortable to grasp to pull the hatch closed.
Does anyone else see this or think it's wrong ???
Old Dec 16, 2008 | 04:28 PM
  #135
mole177's Avatar
^ my palm faces up using my right hand to close the hatch.
but then im tall enough (im sure you are too) to just reach on the outside edge of the hatch itself to close it.
Old Dec 16, 2008 | 05:03 PM
  #136
Virtual's Avatar
Right hand palm facing up grab handle, step to the right side, turn your body so that you're facing left in relation to the car then pull down. It allows for easy full arm swing to close hatch. Works for me.
Old Dec 16, 2008 | 06:28 PM
  #137
jrlnc's Avatar
Thanks mole & virtual.
It will just take some getting used to.
I guess this is a new "neat" feature.
Old Dec 16, 2008 | 09:29 PM
  #138
halfmoonclip's Avatar
Originally Posted by Roger's Fit
One to drink and 2 to P!$$ in.
The abundance of cup holders also explains why the gas tank only holds ten gallons.....and it will still last longer than I do!
Moon
Old Dec 16, 2008 | 09:31 PM
  #139
Rubba Burna's Avatar
HID Addict
in an 08 sport, the little box next to the hand brake, store you cheeze-it there!
Old Dec 16, 2008 | 10:31 PM
  #140
Tork's Avatar
Oh it's going to be a little relay shaped object with a little speaker in it. Just cover that up with electrical tape.
I rarely shy away from tampering with stuff but with this, the wrong tamper could change the way the airbags fire, or the seat belt tensioners working properly. so just going to tape it up good, usually cuts the noise by 80-90%
