Canadian audio system????????
Old Oct 4, 2008 | 10:02 AM
FitCanada_Girl's Avatar
Ok, Honda Canada seriously screwed up on their listed data for the audio system in the '09 Sport Fit. Some places I see this listed as 160W, others say 200W (wasn't it that last year??) Also, I'm assuming that by "6 speakers" they really mean 1 speaker in each door (as per LX) plus 2 tweeters mounted at the corners of the front dash. However, the LX I'm currently driving also has those tiny speakers (I'm assuming that's what they are) mounted in the same place. What gives?
Lastly, every advertising (Honda Canada website, small brochure, full brochure) lists a 5 mode equalizer in the Sport. However, the owner's manual and the car itself do not have an equalizer! I've looked everywhere and tried every button configuration for the stereo system, but no equalizer. Am I just overlooking something? I don't think so but Honda Canada and my dealer are adamant that there IS an equalizer in my car. Hopefully other Canadian Sport owners can chime in here as this is very frustrating...
To sum up, is the 2009 Sport audio system 160W or 200W and is there a 5 mode equalizer in the car? If yes, how do you access this EXACTLY?
Old Oct 4, 2008 | 10:36 AM
Virtual's Avatar
Originally Posted by FitCanada_Girl
... However, the LX I'm currently driving also has those tiny speakers (I'm assuming that's what they are) mounted in the same place. What gives?
I don't think the tweeters are installed on the LX. They look like they are but it's only the grill there.
Old Oct 4, 2008 | 10:39 AM
Well if the tweeters are tiny circles mounted far forward, at each corner of the dash (up by windshield), then both my Sport and the LX I'm currently driving have them. Unless they don't actually work in the LX but then why would they have put them there?
Old Oct 4, 2008 | 10:40 AM
Note that Honda Canada has now amended their website by REMOVING the 5-mode equalizer listed for the Sport. I called them Tuesday and after some explaining, they promised to "look into it". However their 2009 Honda Fit brochures DO list an equalizer....
Old Oct 4, 2008 | 10:42 AM
Virtual's Avatar
Costs less to make only one mold of the dash parts. I think they're empty (No sound from them).
Old Oct 4, 2008 | 10:45 AM
I'll have to test that out on my LX. Would make sense though having "empty" non-functional parts seems silly. Well, as you say, it may be due to cost savings which would explain the situation.
Old Oct 4, 2008 | 12:37 PM
I took a picture of the spec sheet on my car the fist day it arrived at my dealership. I zoomed in on the audio specs and you can see that it clearly says 200W.
I could have sworn my Owner's Manual said 160W. Since I don't have access to this (don't have my car), could someone else in Canada check to see what they say about the watts? I already KNOW that the manual says nothing about an equalizer...
Old Oct 4, 2008 | 12:50 PM
CrystalFiveMT's Avatar
For the tweeters, you can either look for that round chrome center that you usually see in speakers. Or, turn the bass all the way down and the treble all the way up and turn up the volume and see if you can hear anything from the tweeters.
As far as the stereo, we have the same here. They sometimes advertise 200W, but it's 160W across the line. Interesting that they did this as the outgoing Sport had 200W...or did it?, as well as the EQ.
Old Oct 4, 2008 | 12:55 PM
....on my way out to the car to run this experiment. I don't know what is going on with Honda's advertising on the 2009 Fits! 200W or 160W, 5-mode equalizer or not??? It doesn't really matter to me either way but I do like to know the proper specs for the car I'm driving!
Old Oct 4, 2008 | 01:02 PM
So I can now report that the Canadian LX does NOT have operational tweeters. There are "faux tweeters" installed at the corners of the front dash but they don't actually work.... yes, I do have a very high "need to know" factor.
Old Oct 4, 2008 | 01:12 PM
FanOfFit's Avatar
As I remember seeing, the DX have 2 speakers, the LX have 4 speakers (therefore no tweeter...my Ody DX have those too, but not connected), and the Sport have the 160W, 6 speakers and 3-mode equilizer.
Old Oct 4, 2008 | 01:16 PM
Both the LX and Sport (haven't sat in a DX) have 1 speaker in each door for a total of 4. The Sport also has 2 tweeters at the front corners of the dash. The LX has "faux tweeters" in the same spot (don't work). No equalizer of any kind in the 2009 Sport....
Old Oct 4, 2008 | 02:50 PM
FanOfFit's Avatar
If you push the big button repeatedly you can adjust the bass, mid and treble. I guess that's still a poor man equilizer in my book, on the other hand, I been leaving everything on 'C' or neutral settings as I thought the sound is quite good right out of the box (at least with mp3/cd's). Classical not as good but not bad.
Old Oct 4, 2008 | 02:53 PM
Yeah, the button with the music note on it lets you adjust the treble, bass, etc. That button SHOULD have been where you could access the 5-mode equalizer, but it's just not a feature the car has despite all of Honda's press/advertising. They really need to fix that oversight fast! Although it isn't a huge inconvenience not have the EQ, it is a disappointment when the brochure/website tell you to expect it in the car and it ends up not being there! Not good for customer relations....
Old Oct 4, 2008 | 04:27 PM
FiveFreshFish's Avatar
True. Look at the three-switch pod on the lower dash. The LX has no switches and is provided with three blank covers. Personally, I wish the pod wasn't there... knee sometimes hits it getting in or out.
Old Oct 4, 2008 | 04:58 PM
Virtual's Avatar
That is the fusebox access panel. Just under the 3 blank spaces is a handle that you can pull to open the access.
Also note that the "faux tweeters" are on the DX model too.
Old Oct 4, 2008 | 06:10 PM
mega56's Avatar
This happens to me all the time!
Old Feb 18, 2010 | 02:53 PM
vickenp's Avatar
Also owning a 09 LX in canada - I was thinking of adding the tweeters...ANyone do it? they are $49 each at the dealer, but no one knows if the wiring is there or not.....Do u know?
Old Feb 18, 2010 | 08:26 PM
olias's Avatar
These are not "faux tweeters". They are empty grills that pop off by hand. Pull one off and take a look for the wires. I did on my DX and there are NO wires. If you're going to add aftermarket tweets then look at Amazon. They sell the Pioneers TS-T15 for 40 bux.
Old Feb 20, 2010 | 06:54 PM
olias's Avatar
Okay, for you fellow Canuks BestBuy.ca has Alpine 6.5" Component Car Speaker (SPS-600C) for $99.99 and if you price match at FutureShop you save another 10%. So to recap FutureShop's price match police gives you the SPS-600C for $95 CAD.
Alpine 6 1/2" Component Car Speaker (SPS-600C) - Best Buy Canada
Fizz
Dec 27, 2017 02:54 PM
peterspickledpepper
Apr 24, 2015 01:31 PM
guacamole
Jul 27, 2014 08:49 PM
FitCanada_Girl
Aug 29, 2008 07:43 PM
phylae
May 21, 2007 09:09 AM
