GPS Mounting Solutions
Old Mar 21, 2009 | 11:46 AM
  #41
CBX's Avatar
CBX
I have heard of a few more recent installations. Post your pictures!
Routing ideas for XM/Sirius power and antenna cables, too!
Old Mar 21, 2009 | 02:13 PM
  #42
mikejet's Avatar
Suction cup to the window in front of the driver side window, that small porthole.
Old Mar 22, 2009 | 09:30 AM
  #43
crst4s's Avatar
IPAQ Travel Companion
Easy to see, reach, and remove. Power cable routed behind dash to 12v outlet.
Old Mar 22, 2009 | 11:40 PM
  #44
CBX's Avatar
CBX
Routing a cable behind the dash could have numerous applications. Can you elaborate? Thanks for your contribution.
Old Mar 23, 2009 | 01:14 AM
  #45
crst4s's Avatar
I fed the power cable behind the center console below 12v outlet, routed behind lower dash panel and fuse access panel to exit where dash meets airbag panel (see left of GPS). No need to remove any panels. Easy to do just by dropping fuse access panel down. When in use I just plug into power outlet. Hardwire for radar detector is fed through front tweeter opening as per earlier post in this thread, with remote warning light/mute mounted on top of steering column with velcro dots.
Old Aug 15, 2009 | 01:27 AM
  #46
CBX's Avatar
CBX
I have updated the wiring for my GPS installation; https://www.fitfreak.net/forums/2nd-...power-tap.html
Brain Champagne
Dec 20, 2010 02:48 PM
know-nothin
Apr 1, 2010 06:08 PM
runbikerun
Jan 13, 2009 01:16 PM
coopula
Dec 29, 2007 11:45 AM
bestfit
Apr 6, 2007 10:08 AM
