? Keyless entry/newfound autolock procedures
Old Nov 2, 2008 | 01:21 PM
07FitSBOM's Avatar
? Keyless entry when you press unlock on the key FOB, it only unlock the driver door and you have to press on the key FOB again to unlock the remaining doors, just wondering if it is possible just to press on the key FOB only once and unlock all doors at once or is it default as the factory sets it to press twice to unlock all doors. I also tried Crystal5MT procedure on the door auto unlocking features which it work but with a twist and I found out also about something else, wonders what this procedure do:
-Turn iginition key to the II position without starting the car
-Press and HOLD the "lock" position and waited 5 sec, you will hear only 1 click there is no 2nd click, I tried this several times just to confirm that their is only 1 click
-Then immediately remove the key
My guest is that this procedures is the auto locking features for all doors when you're in drive mode, but isn't it the 5MT comes default with the auto locking features when you reach 9mph. I can't tell what it does but it is a procedure you can tried.
Old Nov 2, 2008 | 04:22 PM
solbrothers's Avatar
honda put it that way as a safety feature.
Old Feb 21, 2009 | 12:56 PM
blythe's Avatar
I can't get the procedure to deactivate the autolock to work!!! I've followed these directions, the directions in the manual, etc. When I hold down on the lock button, I never get that click. What am I doing wrong??? Anyone else had a problem getting this to deactivate?
Old Feb 21, 2009 | 02:38 PM
lilaznphatboy's Avatar
the click sounds like the door is locking itself again. ive tried it n it works fine. the first day i got the my FIT, i started messing around with the locking. i activated the auto lock then deactivated then now its activated again.
Old Feb 21, 2009 | 07:26 PM
blythe's Avatar
Yeah, I never get that click when I try it
Zute
Apr 28, 2024 06:54 PM
Press Fit
May 13, 2018 10:56 AM
Jo Anna
Apr 15, 2016 01:25 PM
zhingket
Mar 26, 2011 09:48 PM
jenhonski
Oct 22, 2008 11:25 PM
