Can you disable keyless entry on 2015 FIT EX?
Old Apr 15, 2016 | 01:39 AM
Jo Anna's Avatar
I sit in the car a lot. I turn off the engine and then lock the door.
It worries me that because I have the fob in my pocket that anyone can just unlock my door by pressing the button on the handle.
Is there a way to disable/reenable it so that I can feel more safe sitting in the car?
Old Apr 15, 2016 | 01:47 AM
dwtaylorpdx's Avatar
Most cars disable the feature on the door handle, if you turn the key to ACC.
If that's not the case on your fit, it might be possible to put a switch in to disable the door button. Would have to trace the wiring in the door though..
Old Apr 15, 2016 | 03:21 AM
markkgilbertson's Avatar
Might want to test your theory. I think the car knows the key is inside so it wouldn’t unlock from the outside.
Old Apr 15, 2016 | 12:52 PM
simonx314's Avatar
Mark is correct. The car knows the keyfob is inside the car so it won't allow intruders to unlock the door.
Not only does the car know the key is inside, it knows where inside the car the key is. Try starting the car while the key fob is in the back seat. It won't start.
Old Apr 15, 2016 | 01:25 PM
ezone's Avatar
I think the small button on the door handle can only lock the car when pressed.
Zute
Apr 28, 2024 06:54 PM
Eric Schumann
Apr 17, 2020 08:48 AM
snit fit
Jul 29, 2017 11:22 AM
MontrealBagel
Jun 21, 2014 06:14 PM
07FitSBOM
Feb 21, 2009 07:26 PM
