Another review, from CanadianDriver
Old Nov 14, 2008 | 12:12 AM
FanOfFit's Avatar
CanadianDriver: Test Drive - 2009 Honda Fit LX
Old Nov 14, 2008 | 09:28 AM
FitCanada_Girl's Avatar
Thanks! + Rep to you. Note that they are STILL reporting a 200W audio system in the Sport with 5 mode equalizer. This is false. The audio system is 160W with NO equalizer.
Originally Posted by FanOfFit
Old Nov 14, 2008 | 09:46 AM
cojaro's Avatar
So the CDM Fit base gets the Civic Hybrid wheels? Hmm, interesting...
Old Nov 14, 2008 | 09:54 AM
We get 3 models up here. The DX (steel wheels with covers), the LX (yup, with the Civic Hybrid butt ugly wheels), and the Sport.
Old Nov 14, 2008 | 10:29 AM
M4psycho's Avatar
Interesting, he noted that the fuel economy readout had an average of 6.7L/100km but he was getting close to 8.9....that is a HUGE difference haha. Kinda makes me wonder, 'cause I'm on my second tank of gas and it's been sitting around 6.7L/100km for the last little while ;x
Old Nov 14, 2008 | 12:55 PM
Fitlurker's Avatar
The onboard computer might be a little optimistic as others have reported. In the real world, need to manually calculate it using (known liters burned X 100) / (km traveled). Even then it is just an estimate but much more accurate then readings from the car.
The hard part is getting the actual liters used and assuming the odometer is accurate.
Old Nov 14, 2008 | 01:11 PM
M4psycho's Avatar
but this is the first report that i've seen, showing that the computer is off by THAT much. So he must have been stopped a lot or left the car idling a lot. for it to change by that much.
Old Nov 14, 2008 | 01:30 PM
mega56's Avatar
pure city driving in my first 3 tanks i'm getting around 8.9L/100km, computer reads 7.5-8.0L/100km.
I drive really slow too, but I think I might be shifting too early. Will try to stay in the 2.5-3k range for my next tank
Old Nov 14, 2008 | 01:38 PM
M4psycho's Avatar
I'm only on my second tank, which will probably be empty by the end of this weekend, but on my first tank it read 7.1 and I calculated about 7.2. Actually might have been slightly higher since I only filled up to the point where the pump clicked and I didn't top it off anymore. Now my computer is reading an average of 6.7....will see what my calculated value actually is by the end of this weekend!
As for shifting, I'm usually trying to stay between 2-3k RPMs, and shift usually around 3. On the odd occassion where traffic's heavy i might stay in 2nd gear and that'll cause some more strain on the engine when it's working under 2k RPM, but for the most part that rarely happens so I don't have a huge issue with it.
Old Nov 15, 2008 | 10:46 AM
With my Sport Auto I'm averaging 6.5 L/100 km (5.8 L/100 km on the BSM). That works out to 36 US MPG. I've had my car for almost 2 months now.
Just had my winter tire/wheel set installed (15" Honda steel wheels) this AM and will track how my mileage is impacted. I got the Nokian Hakka Rs which are "ultra low rolling resistance" tires which apparently results in less fuel consumption that other winter tires. Well, I'll believe it when I look at the numbers. But also, our temps are now falling which will further negatively impact fuel consumption. Best I can do is assess how my mileage in the winter months differs from the warmer months (worse due to snow tires AND colder climate).
Old Nov 15, 2008 | 01:01 PM
Fitlurker's Avatar
Since you have snow tires on, I assume the diameter is a little shorter than stock. The km will be slightly exaggerated and need to factor this in your calculations as well.
Old Nov 15, 2008 | 03:15 PM
According to this website, speedometer readings with my new winter tires will be 1.1% too fast (example: when my speedometer reads 60 km/hr I'll actually be going 59.3 km/hr) : Wild Weasel's Automotive HowTo Pages
Of course I expect my odometer reading to be off a bit too but I wouldn't actually go to the trouble of figuring out EXACT numbers. I just want a general ideal of fuel economy in warmer months vs. summer months. The different tire sizes will complicate the issue so I'll keep that in mind...
Old Nov 15, 2008 | 03:31 PM
Fitlurker's Avatar
Yup. The temperature, the new tires, the tire pressure, all those things will add up and affect the FE no matter how small.
Old Nov 16, 2008 | 04:38 PM
CrystalFiveMT's Avatar
You know, the one thing thing the Canadian Fits get that the US doesn't is heated mirrors.
Old Nov 16, 2008 | 04:40 PM
Fitlurker's Avatar
And a bigger washer fluid reservoir i think.
Old Nov 17, 2008 | 05:50 PM
Hownet's Avatar
This is not fair!! They got armrest for M/T model
Old Nov 18, 2008 | 02:04 AM
Fitlurker's Avatar
Trade you armrest and heated mirrors for VSA and NAV.
mav238
Oct 23, 2012 10:27 PM
rav
Aug 27, 2010 07:41 AM
awptickes
Aug 12, 2009 07:09 PM
percy
Jun 17, 2008 04:06 AM
jvolstad
May 8, 2006 10:48 AM
