Work wheels JP suggest 195/50-16 tires
Old Dec 16, 2008 | 07:57 AM
hanzo's Avatar
ホンダ
フィット DBA-GE8 4H-100 16×7JJ+54(A) A 195/50-16 16×7JJ+54(A) O 195/50-16
????????????????WORK?
I though our 16" use 55 series side wall.
Old Dec 16, 2008 | 09:25 AM
projekz's Avatar
I'm running 195/50r16 yokohama AVS winters on my stock rims and it's good. No problems at all. As you go to a wider tire you have to decrease your sidewall.
Old Dec 16, 2008 | 09:37 AM
GD3-Fit's Avatar
I <3 SPOON
195 on a 16x7? if ur slammed ok but other than that go wider 205/45
Old Dec 16, 2008 | 12:19 PM
SRLNCLT's Avatar
195's will work just fine but like GD3 said, I'd go 205/45
Old Dec 16, 2008 | 01:48 PM
hanzo's Avatar
I guess my question is don't you have to keep the same diameter overall as the stock to keep the odometer working correctly? I can see moving to 50 or 45 series side wall on a 17” rim.
Old Dec 16, 2008 | 02:56 PM
eldaino's Avatar
on the gd3, the stock sport tire size was 195/55/r15. slapping oem 16's on it came with a honda reccomended 205/45/r16 size. if you have to follow those rules, you would have to run like a 40 sidewall to do a 205 width tire on the new fit. i absolutely hate the stock tire size. it limits the cars abilities so much.
Old Dec 16, 2008 | 03:01 PM
hanzo's Avatar
From my research on tirerack 205/55-16 has the most tire options. 205/50-16 has much less choices.
Old Dec 16, 2008 | 03:19 PM
hanzo's Avatar
Looks like the Dunlop Direzza Sport Z1 has very good street performance, near R compound grip: Dunlop Direzza Sport Z1 Star Spec
For 16x7" rims
89V
Treadwear: 200
Traction: A
Temperature: A200 A A
Price: $106
Old Dec 16, 2008 | 09:10 PM
SRLNCLT's Avatar
For 16x7" rims
89V
Treadwear: 200
Traction: A
Price: $106
Those tires will most likely be too tall. You would need 45 series, you may be able to squeeze 50 series. My dad is using 205/50/16 on his lowered 95 Integra without any issues.
Old Dec 16, 2008 | 09:25 PM
hanzo's Avatar
The stock Fit sport wheels uses 185/55-16. Why wouldn't it fit?
Old Dec 16, 2008 | 10:15 PM
SRLNCLT's Avatar
205/55 will be quite a bit taller and you may have rubbing issues.
Old Dec 16, 2008 | 10:40 PM
Virtual's Avatar
Because the second number is the profile. It's 55% of the width.
185 and 205 will have different sidewall height. 55% of 205 will be too tall.
Use a lower profile number when going to a wider tire.
Old Dec 17, 2008 | 09:08 AM
hanzo's Avatar
Gotcha, learn something new everyday.
Old Dec 17, 2008 | 09:49 AM
Virtual's Avatar
Glad to be of help.
Btw, the first number is the width in mm and the last number is the rim diameter in inches. Both metric and SAE systems used. Go figure.
Old Dec 17, 2008 | 03:09 PM
jelliotlevy's Avatar
ホンダ
The Sport uses 185/55 x 16. The 50 series 195/50 x 16 is a wider tire with a lower profile. Because of a slightly lower total radius, they would cause the engine to spin about 1.4% faster at any given highway speed. Example: less than 1 mph error at indicated 60 mph. That error is small enough to not be a consideration. I would want to be sure that the wider tire would still fit on the OEM wheel.
Old Dec 17, 2008 | 03:40 PM
hanzo's Avatar
From what Virtual explained the 50 series side wall will be perfect for a 195 tire.
Old Dec 17, 2008 | 04:14 PM
SRLNCLT's Avatar
The answer to all of your tire questions.
Tire size calculator
txmatt
Mar 23, 2021 04:55 PM
andre181
Sep 29, 2015 08:45 PM
bigbacon
Jul 28, 2015 10:23 AM
JDM-Taffeta-S
Aug 18, 2011 10:05 AM
carloso
Feb 9, 2011 10:08 PM
