avic f90bt in 09
Old Dec 22, 2008 | 11:47 PM
reako's Avatar
Originally Posted by rehkopf
MySpace
bought the nav panel from honda for $35, used a new accord wiring harness, and the plate the came with the radio(trimmed up a bit) it's supported by a somewhat modified bracket, local stereo shop did it since i was hearing about all the problems but they said it wasn't that hard at all. ipod is hooked up through the factory plug.
Thanks!...........
Old Dec 22, 2008 | 11:50 PM
bryanfor311's Avatar
can someone please host those pics and post them on here for those of us who dont get into myspace????
Old Dec 22, 2008 | 11:54 PM
rehkopf's Avatar
sorry brianfor311, don't know why it wouldn't let me post on fitfreak
Old Dec 23, 2008 | 12:11 AM
bigtoepfer's Avatar
volume knob is a little small, not that big of a deal (unless a put an aggressive spring rate drop on it, then might get a little annoying)
volume knob small?! LMAO i don't like the look of the radio because the volume knob is FREAKIN HUGE. But i had a AVIC D3 and the volume knob on it was about 1/3 the size of that one.
Old Dec 23, 2008 | 08:47 PM
713_fit's Avatar
the myspace page link does not work?
i cant view it?
Old Dec 23, 2008 | 08:50 PM
rehkopf's Avatar
Cool myspace page is rehkopf*
right click the link and click on open link, it should work,
Old Dec 23, 2008 | 09:36 PM
713_fit's Avatar
is ur fit a USDM fit?
i dnt remember my passenger air bag light to be at the bottom..i thought it was next to my hazard light button?
or is the navi panel different?
Old Dec 24, 2008 | 01:34 AM
dman's Avatar
Pics posted!
Old Dec 24, 2008 | 01:48 AM
raigomaru's Avatar
finally! sorry it took so long for much anticipated pics and for the pics on myspace instead of fitfreak, stupid computer!!! i did get the update from pioneer for free, bootup is only a few seconds. bluetooth works great(mic is up by my rear view mirror), nav has a dudes voice, volume knob is a little small, not that big of a deal (unless a put an aggressive spring rate drop on it, then might get a little annoying) xm is hooked up, antenna is mounted under the windshield wiper plastic (still very good reception) btw was factory no nav. dvds look and sound really good even with stock speakers (dolby digital) haven't messed with the sd card or usb yet
o0o0o0o please tell me there's an option to switch to a Female voice, preferably with an Australian or English accent.
Is it ok to assume that this will have no problems playing off a usb thumb drive? I refuse to buy any ipod-type products
Old Dec 24, 2008 | 02:09 PM
skyghene's Avatar
The airbag light is relocated with the trim piece from the navi version. This is looking really clean and it's definitely something I need to do.. when I get some cash
Old Dec 24, 2008 | 04:03 PM
713_fit's Avatar
Ok so what wire harness adapter do i need to get or use when i buy this unit?
i think i am going to do the sameting..
debating between a avic p90 or avh4000
navi or no navi?
hmmmmm
of course i want navi..but money is an issue...
Old Dec 24, 2008 | 04:32 PM
  #32
bigtoepfer's Avatar
well if i was you i would go with the AVIC F90P because the differnce in quality is a night and day. Do yourself a favor and save the extra 300 or whatever. because you don't have to pay 1000 or 1100 what ever people are trying to charge. And its just not worth it to jip yourself like that and go with the 4000. trust me i'm speaking from experience. Also check this
Originally Posted by JDM_DOHC_SiR
You guys just need this little kit to solve all of your problems...
Or you can get the metra peices
Metra
Wiring harness - 70-1729
Antenna adapter - 40-HD10
However you still would need to ghetto rig the bracket until a better kit can be made by metra. Some are saying number 99-7898 metra kit works too. As a kit to hold the radios. Not real sure on it tho.
Old Dec 25, 2008 | 04:02 AM
  #33
Blackout's Avatar
dont fret buddy i have a USDM 09 sport AT w/NAV and the air bag light is at the bottom
Old Dec 26, 2008 | 03:58 PM
  #34
713_fit's Avatar
does this f90 uses satellite gps??
Old Dec 26, 2008 | 04:30 PM
  #35
reako's Avatar
All GPS receivers use satellites. Here's a link to the spec sheet which may help answer your question: Pioneer USA - In-Dash Navigation
Old Dec 26, 2008 | 05:13 PM
  #36
713_fit's Avatar
not all
some are preloaded onto the hard drive with cd/dvd drives
it says flash memory
what does flash memory mean?
Old Dec 26, 2008 | 05:25 PM
  #37
Olyar15's Avatar
not all
All GPS use satellites. That doesn't mean that they get the map data from the satellites.
Old Dec 26, 2008 | 05:58 PM
  #38
713_fit's Avatar
ok....well let me be more specific than
Does this avic f90 get the map data from satellites?
i know on the specs sheet it says flash memory, but i am not quite sure what that means.
Old Dec 26, 2008 | 06:36 PM
  #39
reako's Avatar
Same answer....you won't find a GPS receiver that gets map data from satellites. May I suggest reading a brief description on the fundamentals of GPS which may help formulate your question?
HowStuffWorks "How GPS Receivers Work"
Flash memory is memory that can be electrically erased and reprogrammed. More information about this here:
Flash memory - Wikipedia, the free encyclopedia
The F90 stores map data on flash memory. This allows map data updates by simply overwriting these areas directly, as opposed to buying an expensive new DVD after years of development.
Old Dec 26, 2008 | 06:53 PM
  #40
rehkopf's Avatar
thanks dman for posting those picks, i hope they helped, sorry i couldn't get em on fitfreak
