automatic gear shifter
Old Jan 25, 2009 | 05:35 PM
1150bob's Avatar
I want to replace my automatic gear handle with the new blue threaded one. I can not find any installation instructions online. Has anyone done this yet.
Old Jan 25, 2009 | 07:19 PM
kylerwho's Avatar
spoon fed
give it a week and i will be doing a diy on installing an automatic shifter knob on the fit. i will be doing it on a gd3 but the install should be the same for the ge8 as well.
Old Jan 25, 2009 | 10:05 PM
badself's Avatar
In lieu of instructions for the 2009 (couldn't find them on College Hills or anywhere else), here are the instructions for the 2008 auto shift knob:
http://www.collegehillshonda.com/ins...cshiftknob.pdf
Old Jan 26, 2009 | 08:27 AM
Lek's Avatar
Lek
Just get one of these made at your local leather shop for a fraction of the price. Mine cost about $35. In whatever color stitching you like.
For removal, just snap off the plastic on the front and undo the screw. Sorry, I don't have a pic.
Old Jan 26, 2009 | 11:31 PM
1150bob's Avatar
Thanks for the responses. I don't see any outside screws. I guess the center console has to be removed to change knobs.
Old Jan 26, 2009 | 11:42 PM
kylerwho's Avatar
spoon fed
you dont have to remove the center console to change the knob.
here is the diagram. look at the bolt that holds on the shifter lever.
Old Jan 26, 2009 | 11:52 PM
1150bob's Avatar
Thanks, Kyler, I will try again tomorrow to locate that bolt.
Old Jan 27, 2009 | 02:59 AM
Lek's Avatar
Lek
I watched the guys in the leather shop do mine. They just pulled off the plastic No 7 and took out the screw No 18. Be careful taking off the plastic cover, mine was tight.
Old Jan 27, 2009 | 12:32 PM
luv4jdm's Avatar
Its true, I'm trying to do this mod myself too but there is no screw like the GD. The GE is all plastic and no screw on the base of the shifter??
Old Jan 27, 2009 | 12:43 PM
secondspassed's Avatar
did you even look at the diagram????
Old Jan 27, 2009 | 03:09 PM
luv4jdm's Avatar
oops my mistake, I thought the diagram was for GD not GE
Old Jan 27, 2009 | 08:48 PM
kylerwho's Avatar
spoon fed
the diagram is for a ge.
Old Jan 27, 2009 | 11:55 PM
1150bob's Avatar
I get the impression that the screw is inside the handle. It looks like you have to pry the two pieces apart then remove the screw holding the back part to the shaft. Who is going first?
Old Jan 28, 2009 | 02:47 AM
kylerwho's Avatar
spoon fed
people have already done it. just pry off piece number 7 starting from the bottom and it will just pop off. then you have full access to the screw that holds the back piece on.
Old Feb 4, 2009 | 12:06 AM
1150bob's Avatar
Well, I got my new knob today and was installed in a few minutes. You only get the back half so you have to reuse the original front piece. Bought on line to save a few bucks. Thanks to all who replied.
nisco
19
Jul 15, 2019 11:16 AM
Farther
Sep 12, 2010 06:49 PM
runnin
Jul 16, 2008 07:05 AM
07fitsport
Aug 15, 2007 10:04 PM
Gordio
Dec 21, 2006 11:14 PM
