View Poll Results: Kraftworks Super Charger of the 09+ GE Fit ....Yes or No
Yes!!....make the kit please..!!
88.02%
No thanks.... I love my stock GE Fit...
11.98%
Voters: 167. You may not vote on this poll
Yes or No....Kraftwerks Super Charger 09+ GE Fit
Old Nov 14, 2010 | 02:49 PM
  #121
rohmbd's Avatar
I too would like a supercharger kit.....get going please.
Old Nov 14, 2010 | 03:05 PM
  #122
Goobers's Avatar
I thought part of the problem with the GE Fit was, there isn't a whole lot of room to work with.
If the engine wasn't partially under the front dash, at least you could just replace the hood to give it more room.
edit:stinking typo
Old Nov 14, 2010 | 07:31 PM
  #123
Lyon[Nightroad]'s Avatar
Space is a bit difficult with a turbo since you have to bring the plumbing around to the the front, but with a c15 series supercharger there are several different options I can see.
Old Nov 15, 2010 | 12:49 AM
  #124
blackndecker's Avatar
Ughhhh.....this thread always makes me envy the GD crowd.
Old Nov 15, 2010 | 12:50 AM
  #125
ThEvil0nE's Avatar
you just don't realize how often I look into the KW site and just stares at those FIT S/Cs
Old Nov 15, 2010 | 12:53 AM
  #126
thefit09's Avatar
bitches ain't shit... I'm not too worried about sc's and turbos... I won't put one on for another two years anyway...
Old Nov 15, 2010 | 01:34 AM
  #127
DiamondStarMonsters's Avatar
Well, if none of these guys follow through, all you need is a sturdy bracket to mount the supercharger and a belt. Once that is sorted I think you will find the rest is not so bad.
Then all you have to do is buy a centrifugal supercharger of some type, something roughly the same flow capacity as a Rotrex C30-74 would be a nice match if you are gonna DIY:
Kraftwerks USA Products
For those that don't want to drop $2200 on a Rotrex S/C, remember there are other proven reliable units from Paxton, Eaton, Procharger, Vortech, Powerdyne, etc.
Whatever you choose once it is mounted figuring out charge piping is easy enough, and relatively cheap if you go through a group like frozen boost, or you could even affordably do a water to air charge cooler for those that don't like the small top mount or that don't want the dead give-away of a front mount. They allow for cooler than ambient IATs, they are used in DD applications, like Fords new compound turbo diesel pickup, and they are very compact!
Something like this will flow 450cfm (~325whp worth of air) and is very compact, and the core alone is only ~$150 dollars!
Water to Air Intercooler - 11"x9.25"x3.5" - Bend I/O (Type 13)
Water to Air Intercoolers
The website looks crappy, but they are legit, I have done lots of business with them and no complaints. I am even on another tuning forum where the owner posts and asks for advice, and he appears to be a nice guy.
Anyways think about whether or not you need to spend ~$3-4k on a kit
With proper fuel injectors and a couple sensors datalogged with an AEM FIC or comparable tuning hardware you would be all set. From perusing their forums, and downloading the software, the FIC doesn't look nearly as intimidating as AEM's full standalone ECUs.
I think it would be alot more doable for the average FitFreak, all they have to do is alot of reading, and gradual tuning. Base Maps are abound, and that is enough to get you to work or the grocery store while you dial in the power on the weekends!
I also found another group called Neukin that makes turbo adapters for the GE L15A70s for $200 :
Neukin AX Honda Fit L15A7 Turbo Manifold
You guys have options!
Old Nov 15, 2010 | 11:53 PM
  #128
I'm curious why you recommend the c30-74 over the c15-60? Wouldn't the larger unit be harder to mount, create more parasitic drag below 180bhp, and be more inefficient until you start moving to the limits of the c16-60 at >~190 bhp? Or is this one of those things that would vary depending on my goals. I read corky bell's maximum boost but I still fail to grasp some things.
Old Nov 16, 2010 | 12:34 AM
  #129
Yes it is bulkier, and it will create more drag, depending on the pulley, but it is not necessarily inefficient below 180bhp (~19-20lbs/min airflow)
Now before reading further you may want to run to the john and grab a snack, this is a post from my tech thread. Note: a belt/gear driven centrifugal compressor's map is going to be different from that of an exhaust driven centrifugal compressor, but the concepts in terms of flow and efficiency are very similar.
The information in my post below, when compared with a list of Garret-Honeywell compressors and their recommended mate in engine displacement for given compressor/turbine configurations (The notes in the far right column like "1.4L-2.5L" or "2.0L-6.0L") should pretty thoroughly explain why I occasionally am harsh about the 24-25lb/min GT2554R compressor used in most GD turbo kits, and why I am using a 34lb/min MHI 14B compressor in stead..
So note that the turbine maps, and the different housings with different flow lines are similar in concept to different sized pulleys in the sense that they are the limit to flow and boost.
Hang on its gonna be a bumpy ride!
Well with the release of Bisimoto's CR-Z Turbo Hybrid and what little data I have been able get from the mods and figures/videos posted I am thinking about going far beyond my initial 180-200whp goals...
So in taking a break from studying this evening I was doing a little research on my plans for a turbo L15A and found some interesting stuff..
Before going further, unless you can already read or have a rough understanding of compressor maps and how different turbine wheels and housings can affect what part of these maps you will be able to use... I would read these links (in this order):
Stealth 316 - Turbocharger Compressor Flow Maps
TurboByGarrett.com - Turbo Tech101
TurboByGarrett.com - Turbo Tech102
TurboByGarrett.com - Turbo Tech103
The last one in particular is what I will be dealing with.
I have others that go more technical but that is a fantastic place to get a basic understanding of what I will be talking about..
So a Pressure Ratio of 2 on these maps is 14.7psi boost pressure. 3.0 is 29.4psi boost.
Garrett uses pounds per minute on their maps, which can be very roughly translated as 1lb/min = 8-9whp depending on BSFC, as discussed in the links above.
This first one is from a Garret Honeywell GT2554R which seems to be the turbo EVERY kit for the GDs and all of the alleged developing kits for the GEs has been using, and at only 5-10psi. Which you can see why they run out of steam so soon, especially when some GT25s leave even the 60% efficiency islands at 10psi at ~20lbs/min.
Bear in mind the turbine side is also affecting the compressor map, though it is rare you will actually see a turbine flow map I have some for you, which will also put in perspective the size of the 59mm Compressor Inducer (Borg Warner S259ETT, similar to the S258ETT) turbo I have on my Laser, which is between a GT3782R and a GT4088R when you compare both the Turbine and Compressor sides.
When people talk about 50-Trims.. that should tip you off that they have no clue what they are talking about. Because unless we know which Compressor or Turbine wheel and which housing he is using that information is useless Fast'N'Furious ricer non-sense.
I am of the opinion there are better options. Some of which are cheaper. Lets look at a few of the common street turbo options anyone with a GT25/28 could bolt in..
The HKS/T1R turbo that comes in your kits:
GT2554R :
Compressor Wheel Inducer 42mm/Exducer 54.3mm
Turbine Wheel Exducer 53.0mm
GT2560R:
Compressor Wheel Inducer 46.5mm/Exducer 60mm
GT2854R
Compressor Wheel Inducer 42.0mm/Exducer 54.3mm
Turbine Wheel Exducer 53.8mm
Now note the difference in airflow and efficiency created by the 5mm larger inducer on the GT2860 compressor
GT2860RS
Compressor Wheel Inducer 47.2mm/Exducer Wheel 60mm
This last turbine map illustrates the effect on flow through the engine between different size turbine housings, the red line being a .86A/R vs a 0.64 A/R on the same 53.8mm Turbine Wheel Exducer.
All this was to illustrate the effects of:
1.) Different turbine wheels in the same size turbine housing attached to the same size compressor wheel. Example: GT2554R v GT2854R
They both flow the roughly same amount of air at the same boost and efficiency. This is because the only difference being a slight increase of the turbine wheel (0.8mm) creates only marginal gains, if everything else remains the same.
2.) Different compressor wheels attached to the same turbine wheel in the same turbine housing. Example: GT2554R v GT2560
Using the same exact 53.0mm turbine in the same exact housing the GT2554R's 42.0mm Inducer/54.3mm compressor Inducer can flow about 28lbs/minute max efficiently. Versus the GT2560R's 46.5mm/60.0mm Compressor flowing about ~34lbs/min max.
The only changes being to the compressor wheel and a bigger air inlet (46.5mm inducer vs. 42.0mm)
3.) Different turbine housings attached to the same turbine wheel and the same compressor wheel. Example GT2860RS 0.64 A/R vs. 0.86 A/R Turbine housing.
The compressor maps only tell us part of the story. While the compressor may show it can push 37lbs/min, but because of the turbine combination it may only flow 31lbs/min in the 0.64 A/R Turbine housing using a 53.8mm turbine wheel and remain efficient.
But in a larger 0.86 A/R Turbine housing on the same 53.8mm turbine wheel it can flow the full 37lbs/min. So a 6lb/min gain changing only the housing that bolts the turbo to the engine.
In this example just by swapping to a larger, slightly laggier, turbine housing you can pick up ~40whp at the same boost.
Think of it like blowing through a coffee stirrer vs a garden house less pressure required but more airflow overall.
So now a real quick way to know what you are looking at when comparing maps now that you have the concepts discussed in the links I posted above:
Find say 5psi, 10 psi or 15psi (2.0 Pressure ratio) on these maps, draw a horizontal line and then draw a vertical line where on that farthest right outside island how. That is how much airflow that turbo will flow "efficiently" on that much boost.
You can see a whole bunch more Compressor maps from several companies like Garrett or MHI on that Stealth316.com link which should help you choose a good match for your project and goals!
Hopefully other DIY guys can find this useful and if anyone has any questions just ask, or PM me.
If anyone is curious, I would personally use a GT2860RS in at least 0.86A/R Turbine housing as the very smallest I would bother putting on an L15A for the money involved.
This is why I am using a 34lb/min Mitsu 14B turbo to start. because it has a large enough turbine side to flow all 34lbs/min while still spooling very quickly for it's size.
Remember, the 533whp L15A in Bisimoto's CR-Z turbo is using a Slightly larger turbo than the one I have on my 2.0L.
So if they can spool a freaking 64mm Inducer in a GT4088R on a tiny little L15A, You will have no problems daily driving a GT28xxR or larger. Here's how they do it:
GT4088R
Compressor Wheel Inducer 63.5mm/Exducer 88.0mm
Turbine Wheel Exducer 77.0mm
But look at the difference in flow the 4 different A/R turbine housings make on the same turbine wheel. With the fastest spooling .85A/R being the most restrictive and least efficient, and the laggy 1.19A/R allowing the most flow for top end power.
My whole point in all of this is, do some research if you are going to go turbo, and match things properly to your goals/driving style.
Do not waste your money getting anything in the GT25R family or smaller if you are gonna DIY! (in terms of airflow)
GT28Rs and larger will still provide plenty of torque, same power at less boost which makes it more efficient on pump gas, which is good for longevity, fuel economy and performance on a high compression pump gas engine.
A 38-40/lb/min Mitsubishi "small" 16G would probably be about the perfect monster street/strip turbo for our 1.5L's.
I am not saying everyone should go out and start buying giant GT35Rs or even (kinda) large 16Gs for their Fits, but there are alternatives!
Now for scale and references of what I am babbling with compare sizes on this chart and look at what they recommend to use them on but keep in mind those are rough figures, a couple hundred cc either way doesn't really make or break a turbo unless it was a specific combination of parts, like a specialty OE turbo which are sometimes not very good on other applications. Schwitzer Airwerks K03/K04s like you see on VWs/Audis come to mind.
In closing, for the same reasons I am going to use the 14B turbo, which is a ~430cfm centrifugal compressor, so if I had the intent or funding, I would go with a 450cfm centrifugal compressor.
More air, less boost but no real lag to worry about since it is attached to the crank.
This compressor map for the GT2860RS
Shows 36-37lbs/min is about the most this will efficiently flow, and it does that at almost exactly 14.7psi or 1Bar Boost, which you can see if you draw a line the C30's map is likely comparable to this but I am still looking for the actual Rotrex specs. So you can see that 30-31lb/min or ~280whp on a fwd manual @ only 7.x psi boost is pretty appealing.
So depending on whether or not our stock fuel pumps can flow well enough (or if they have a pressure release valve) you could bump base fuel pressure up to 50-55psi using an adjustable fuel pressure regulator, and that would allow you to deliver enough fuel to get away with only tiny little RDX 440cc/min injectors.
So a bracket, belt, fuel pressure regulator, injectors, UEGO/EGT, supercharger, piping/couplers, intercooler and a tuning device is all you need to DIY.
Before anyone says "Thats way too big" look at that Garrett table.
Look lower ... lower.. They consider the basketball sized GT4708R Compressor with a 1.39A/R T6 Turbine housing a feasible turbo for a 2.0L application going all the way up to 10.0L. That is a 1400hp compressor
Not that it would be an awesome street setup, but that is not the point.. it is to suggest there is flexibility depending on your setup and goals.
Bisimoto's "tiny" GT4088R is only good for 700HP for comparison.
The Borg Warner S259 I just put on my Laser is just in between a GT37 and a GT40 and has proven to be a lot of fun, The 14B is the turbo I used to break in the built 2.0L currently in the Laser, and made a little more than 320whp and 350lb-ft spiking to 21psi @ 2900rpm in 3rd and holding 18psi to redline.
Old Nov 16, 2010 | 08:41 PM
  #130
HiVolume.com's Avatar
I spoke with Oscar Jr. @ KraftWerks in late June, after buying an S2000 kit from them, and mentionned my interest in a S/C kit for the GE. He was quite confident this wouldn't happen...
Has anyone looked into adapting their GD kit for the GE?
Old Nov 17, 2010 | 02:49 AM
  #131
In closing, for the same reasons I am going to use the 14B turbo, which is a ~430cfm centrifugal compressor, so if I had the intent or funding, Iwould go with a 450cfm centrifugal compressor.
Thanks for the reference material! I'm starting to have misgivings about the rotrex units anyway due to pricing. As I make my plans for next spring I'm starting to think it may be more cost effect to get one of the many many used/rebuilt turbos available for for well under a grand. If I do go that route I have a feeling you will be invaluable in helping me select the appropriate unit for my modest goals. In the meantime I think that, despite unreliable dyno graphs and a comparatively high price, I may indeed purchase the WR 'header'. The design looks like it would be a cakewalk to have a shop weld on a flange to the 'header' if I take the plunge. The key thing for me is that I want to work in steps i.e. 5psi untunned, add aem fic, spend a while just tunning the stock setup to 5psi, upgrade injectors, upgrade wastegate, retune for 8psi, etc. etc. That would make for a great way to spend 2011
Mr. 773
30
Sep 11, 2010 02:28 AM
555sexydrive
33
Aug 7, 2010 09:53 PM
boostedk20a2
Kraftwerks
51
Jul 16, 2010 02:33 PM
sedanimal
Aug 24, 2009 03:32 PM
JDM.Fanatik
48
Apr 19, 2009 08:13 PM
