A-Pillar Trim Panel Removal
Old Feb 27, 2009 | 10:24 PM
vwli's Avatar
Any one know how to take off the A-pillar trim panel on the driver's side? Is there an air bag behind it?
Old Feb 27, 2009 | 10:31 PM
1FiTpINOY's Avatar
Ummm.....it saids SRS on it.......
Old Feb 27, 2009 | 10:37 PM
AP_ONE's Avatar
All in all it should just pop off as plastic clips hold it and there would be a small airbag along the a frame. Nothing will blow up if you plan to take it off, unless you hit it REAL hard
Old Feb 27, 2009 | 10:50 PM
Virtual's Avatar
Disconnect the battery first just in case.
Old Feb 27, 2009 | 10:52 PM
theloxmyth's Avatar
Fit Gadget Freak
Exclamation The service manual says...
Uh, methinks the Fit service manual says to buy replacement clips because you will break the clips removing the trim.
I also think I remember reading to use a soft-faced mallet, and a cloth to protect the trim, and hit the trim at the clip's location to break it to remove the trim.
That's why you NEED replacement clips!
Gotta go, the Rolex Forums - Rolex Watch Forum is calling me!
P.S. When I ran my ScanGauge wire from the rear-view mirror to under the dash, I simply pulled the trim away from the pillar to route the wire as needed.
The trim DID NOT detach with even a ruffian tug, I tried, though you may succeed!?
Old Feb 27, 2009 | 11:04 PM
vwli's Avatar
I guess my best bet is to tug as much wire under the trim panel as possible. I am just thinking ahead how to wire the mic and clip it on the visor.
Old Feb 27, 2009 | 11:08 PM
AP_ONE's Avatar
Ive never seen a honda that the clips will break on, sometimes rather then snap directly into the frame, the have little round white clips that clip into the frame and sometimes they break but not usually if your careful. just take your time.
Old Feb 28, 2009 | 11:55 PM
GE8's Avatar
GE8
the clips will break on the a pillar because thats what they are designed to do. if you find the instructions for the factory remote start for the ge it tells you in there that it will break and come with new clips in the kit
Old Mar 1, 2009 | 12:07 AM
GE8's Avatar
GE8
here is the instructions for the remote start. it tells you how to pull the a pillar apart
pages 4 and 5
http://techinfo.honda.com/rjanisis/pubs/AI/AII39870.pdf
Old Mar 1, 2009 | 12:26 AM
Tork's Avatar
Loxsmyth nailed it,
when I had the 3 day helm online, it does say hit it with a mallet I think by the srs lettering.'
I highly recommend the $10 3 day online service manual, it has very cool animations
https://www.fitfreak.net/forums/2nd-...helm-pass.html
Old Mar 1, 2009 | 02:02 AM
vwli's Avatar
This is awesome. Thank you for the info.
gg7aph
Aug 16, 2016 10:44 PM
msoulier
Oct 6, 2013 10:19 AM
FightingChance
Dec 7, 2009 02:22 AM
ezduzit
Mar 21, 2008 08:16 PM
mharrigan
Jun 13, 2006 11:38 PM
