Jacking points
Old Apr 10, 2009 | 12:36 AM
halfmoonclip's Avatar
Jacking points
It was time (I hope) to take off the winter treads today, and I thought I'd try the central jacking points to do an axle at a time. The FSM is very clear on their location, as were some posters here.
However, when I tried to slide my (Sears racing) jack under the engine, it was significantly too high to fit under the Fit.
My jack is relatively low profile; wonder if others have had this problem...
With a second jack, it would be possible to lift from the side until the main jack would fit underneath. Any other ideas?
Moon
Old Apr 10, 2009 | 01:53 AM
dman's Avatar
Maybe try driving it on a 2x6" and it'll give you just enough clearance for the jack.
Old Apr 10, 2009 | 06:59 AM
Virtual's Avatar
It is enough. I use that method with two 2x4s and it works.
Old Apr 10, 2009 | 07:27 AM
Good tip, virtual and dman; hadn't thought of that. Buying an extra jack just to use the first one seemed like overkill, but the wood sounds like a winner.
I haven't changed the oil yet; does it require jacking or ramps to get access?
Thnx,
Moon
Old Apr 10, 2009 | 09:50 AM
Virtual's Avatar
Yes. I changed my oil last weekend and lifted the car to gain access to the drain plug.
SilverEX15
Sep 26, 2017 08:55 PM
Thorzdad
20
Dec 16, 2011 12:38 PM
mozarwasagenius
Apr 22, 2009 10:10 AM
GD3_Wagoon
Nov 11, 2008 12:25 PM
diedwater
Mar 29, 2008 10:22 AM
