Help please...need horn upgrade for my "09 Sport
Old Apr 10, 2009 | 09:48 AM
Taffeta Fit's Avatar
Lightbulb Help please...need horn upgrade for my "09 Sport
I'm looking to upgrade the horn on my '09 Fit. I'd like to accompish this without having to do a rewire...any suggestions? Thanks!
Old Apr 10, 2009 | 10:32 AM
badself's Avatar
Yeah, labor intensive as it may be for you, try the search function. There's an entire thread (maybe more) devoted to the subject.
....at the risk of being an ass.
Old Apr 10, 2009 | 10:39 AM
wpyeo's Avatar
a few of the GE owners in SG had a mini DIY meetup to replace the stock horn. below are the steps and pix..
note: our GE are JDM, not USDM. so there might be some differences. but the concept should more or less be the same.
1. Stop car on flat ground and apply handbrake!
2. Open the bonnet.
3. Remove the 4 plastic locks as shown. Use a flat tip screwdriver to lift the head of the locks and pull them out. Keep the locks together at a safe place so that you don't lose them!
4. Once the 4 locks are removed, you need to ply open the top cover a little to look out for the 2 screws securing the grill. There is one screw on each side. Use a cross tip screwdriver to remove the screws. Keep the screws safe!
5. There are 10 clips (6 on top and 4 below) on the grill that holds it to the body. Depress them gently one at a time and remove the grill to expose the stock horn.
6. You need a wrench set (right in the image below) to loosen/tighten the nut holding the horn and a crimper (left in the image below) if you use connectors.
7. Detach the horn from the power connector and remove the nut to take the stock horn out.
8. Tap the power from the existing wire to power the new horn. This is not required if you have the correct terminal to plug into the power connector such that you can draw current from the power connector directly.
9. Get your new horns ready!
10. If you are buying the below horns like me, I must warn you that the hole on the brackets provided are too small for the nut removed at step 7. You need to make it bigger! We used a flat tip screwdriver to scrape the hole till the nut fits!
11. Connect the horns using wires and connectors..
12. Tighten the new horns with the nut and connect the positive lines to the wire you tapped at step 8.
13. Test the horns!
14. Assuming they work, fix the grill back in place. Put back the two screws removed at step 4. Also put back the 4 locks removed at step 3.
15. Get horny!
Old Apr 10, 2009 | 10:40 AM
Thanks for the help
Old Apr 10, 2009 | 10:41 AM
1FiTpINOY's Avatar
Scroll down on this thread and you'll see in "Similar Threads" exactly what you are looking for.....
At least it shows for me ;P
But yeah, there's a thread on here already for this.
***EDIT***
Clicked on the thread 3 times and it showed at the top of the Similar Threads lawlz
Old Apr 10, 2009 | 12:16 PM
badself's Avatar
Originally Posted by Taffeta Fit
Thanks for the help
Sorry, but for me, I'm much more likely to help somebody who puts forth even the smallest effort to help himself.
In retrospect, I should have linked the thread for the plug-and-play Accord horn instead of just digging into you.
https://www.fitfreak.net/forums/2nd-...rn-ge-fit.html
Old Apr 10, 2009 | 12:27 PM
JDM_DOHC_SiR's Avatar
DeltaBond
Aug 26, 2013 04:46 PM
AndrewLOL
Jan 29, 2011 10:37 AM
FITMugen
Jan 22, 2010 11:33 PM
grablefan
Oct 25, 2009 11:57 AM
ccaddy
May 30, 2009 10:43 PM
