2 things for today:
addition to:
https://www.fitfreak.net/forums/2nd-...ml#post1354147
Started all new:
https://www.fitfreak.net/forums/2nd-...iator-fan.html
addition to:
Started all new:
Its been a long while since i've been on here, but I finally ordered some more parts for my car, should have everything by next Thursday. I'll post pic then or sooner
Also BMW keep up the great work, I'm loving your car more and more.
glad to hear from you again,
May I know what parts that you order for your car?
I am sure you are excited and can't wait for next Thursday
I am currently waiting for UPS on Friday for the Earl's sandwich adapter so I can decide the angle of the Goodridge fitting needed and how long the Goodridge 910 hose needed,... I can't wait for my parts to arrive too
Those are pretty slick. Bronze would be pretty hot on your milano red
Hi swflej1,
Spoon front sway bar
Blox Rigid collars (it's for the first gen but I wanted to see if they would work)
Shifter extension.
I may a side job so if that pans out I'll going to try to order motor mounts or save for a new intake not sure yet
I frequent Miata boards for my moms Miata. If you want lightweight and affordable consider the advanti Storm s1 or s2, 6UL, or TR motor sports
Btw
ClubRoadster.net
Hell of a deal right there
Btw
ClubRoadster.net
Yeha I'm on swifts as well and am yearning for more drop, like another 18-20mm to get rid of the wheel gap. Bilsteins have a max drop of 50mm (~2in) so dropping to like 40-45mm would be perfect I feel. Air bags are sweet but cant justify the cost/loss of trunk space. Dont get me wrong I think they are sweet....just wont work for me or my wallet haha.
Hi connor55 and shinjari,
I just want to point out that today we have another satisfied Bilstein user:
https://www.fitfreak.net/forums/2nd-...ml#post1354238
from my past experience,
The Spoon front sway bar will transform your car from a bit of roll in the corner to super flat in the corner with super fast steering response
you will like it for sure
Btw
ClubRoadster.net
Btw
ClubRoadster.net
Hi swflej1,
Hi swflej1,
Where can one get a Spoon FSB? I'm assuming you mean it'll improve the handling in conjunction with the Progress RSB?
but I don't see they stock the one for Honda Fit GE or Honda CR-Z (same)anymore,
but a quick check show you can get it here:
https://www.japanparts.com/parts/detail/44891
or
RHDJapan : Spoon Sports Suspension Stabilizer Set - CRZ ZF1 Fit GE8
or
Spoon Sports Front Sway Bar - Honda CR-Z 2011+ | Shop Spoon Sports parts at KamiSpeed.com
I personally recommend rhdjapan as my favorite and direct source,
follow by japanparts to get JDM parts.
never deal with Kamispeed, beside I think at the end it will be cheaper (when you add shipping) to buy from either rhdjapan or japanparts.com
Yes, it really improve handling,
I think the most important handling changes in rank:
#1 is Coilover
#2 is Spoon Front Sway Bar
#3 is Rear Progress Sway Bar (this will make the ride much bumpier in my experience)
#4 is Spoon Rigid collar (but I change this at the same time I change my front lower arm with Insight Aluminum control arm, so the improvement might come from the newer bushing in the new LCA and increase rigidity of the LCA then from the rigid collar)
and I also add the Cusco 4 point bar at the same time...
Best way is to do it one by one, so you can feel the difference each time you add performance parts...
What I did to save money on alignment at that time was
I install the Coil over myself, then drive it to feel the difference
then go to alignment shop that also do suspension and have them change the sway bar for me and then align it...
so when you drive back from the alignment shop, you feel the different with the new sway bar and alignment...
Got these side mirrors on yesterday but had time today to hook them up to my parking lights.
Not a huge fan of the delay switching from turn signal back to parking light but all in all I'm satisfied with them.
I bought it long time ago on sale at GoTuning, I pick it up myself at their facility near Anaheim...
or
or
#1 is Coilover
or
or
#1 is Coilover
To get air or bilsteins...if only the coilovers went lower that would make the decision easier lol.
https://youtu.be/cIs6Na0TUUY
Thanks man! And ah, I get what you mean; was just thinking if anyone has done any tinkering with stuff like that to bypass it or what not all good though!
or
or
#1 is Coilover
or
or
#1 is Coilover
I agree about the delay, kind of weird that theres 4-5 seconds of nothing before the parking lights engage.
or
or
or
or
I'm trying my luck with AJ'sracing. I know some people haven't had the best of luck so With them, but it was cheaper then get it from the other two site and they had it in stock. It should be here next week I'm hoping
Yeah those are pretty slick. I'm sure those were simple to do considering you just wrapped them right? Don't they come in white or black and require paint? Are these the ones easily found on fleabay?
Yea, I found these on eBay-- the lister was asking for an extra $50 to paint them but I had a friend who hooked me up with paint. These come unpainted and I painted them black in case I ever take off my vinyl. I might wrap it if ever I feel they should be color matched but I will most likely pay a shop to do it as I still don't have it mastered haha.
Yea-- but I guess as long as they do come on, I can't complain lol.
That delay is actually doing you a favour though. Turn signal is just an oscillation of on and off, the mirror circuitry doesnt know the difference between the turn signal actually being off or just an off cycle in the middle of flashing. So if it was set up without a delay, it would flash white in between every orange flash, which would look kinda silly imo. You would need a separate module to actually tell it that the turn signal was on so it would know to keep the white light off in between amber flashes.
Think of it as the white light waiting to be sure that turn signal is really off before coming back on.
Im sure its possible... But you would have to disconnect the circuit boards from the actual leds. Then you would need a series of relays to control the two lights.
Ah true-- it's being a gentleman lol
