+38 offset on stock tires will they rub?
Old Apr 24, 2009 | 09:36 PM
JDM_DOHC_SiR's Avatar
Wow... looks like your poking out a bit up front.... ... if you were a bit lower it might cause some problems.... looks good no the less.....
when you can get that other pick when the wheels come back
Originally Posted by GE8
best side view i have for now i took wheels off to get powder coated.
Old Apr 25, 2009 | 12:09 AM
GE8's Avatar
GE8
i will and yes my bump stops are cut i had them installed at a reputable shop who has done many many installs. also my drop looks the same as everyone elses the gap looks diffent in the pic because of the low pro tire and angle. also my back sits slightly lower because of the system. if someone with df210 wants to post a side view pics with stock wheels/tires feel free i will post one up of mine.
Old Apr 27, 2009 | 01:29 PM
projekz's Avatar
Originally Posted by tdesi420
here ya go
The tires are almost 1 inch too small, did you notice anything different in your highway speeds. Are you revving higher to maintain your speed?
Old Apr 27, 2009 | 02:34 PM
tdesi420's Avatar
the rims are 1 inch smaller, but tires are not.
stock 185/55 has 101.75mm sidewall
these 205/50 has 102.50mm sidewall
So these tires are .75mm thicker than stock. I was told that my speedo will be off just a tad, like while i am going at 60mph, my speedo will read 62mph....or something like that, maybe vice-versa.
Every 1000 actual miles i go, the meter will read 1038 miles....so yeah, i will be off just a lil bit.
As for revs, i may have noticed my rpm's are a lil bit higher than before. I'll double check today while i am on the highway at 60mph. i think i have seen my rpm's were around 2200-2300 after putting this setup at 60mph, bit i'll check again.
Old Apr 27, 2009 | 05:52 PM
tdesi420's Avatar
i checked my rpm's today and
@ 60mph, my rpm is around 2100
@ 70mph, my rpm is around 2500
Old Apr 28, 2009 | 10:37 PM
projekz's Avatar
From what I can gather, the overall diameter on the 185-55-16 is about 24 inches and the overall diameter on the 205-50-15 is 23.1 inches. That would put your speed 3.9% slower than what your speedometer read. Not that is a big deal but your RPM has to come up to make up for the speed difference.
I've got a set of Yokohama A032R in 205-50-15 sitting in my garage right now and I'm really tempted to get a set of 15 inch rims and see what the car can do in corners (once I get my suspension installed). One thing is for sure; there won't be any rubbing with a tire almost 1 inch shorter than stock!
p nut
Sep 11, 2014 04:15 PM
ccl088
Aug 1, 2011 09:41 PM
chinkyy
Feb 27, 2009 04:20 AM
MemphisFit
Sep 27, 2008 11:52 AM
1500cc
Aug 16, 2008 04:04 AM
