Stop the window rattle!
Old May 9, 2009 | 06:32 PM
runbikerun's Avatar
Hey, I got tired of my front driver and passenger windows rattling when they are rolled down just a couple inches.
Maybe everyone has figured this out already but I think I found a fix.
I first pulled out the rubber track that the window runs in along the rear side of the window. There is a fold of this seal that runs along the inside of the window. I bought some 1/4" foam rubber weather stripping. Just clean the inside of this seal with some rubbing alcahol and stick in some weather stripping directly under the fold. Make sure that it sits under the fold so it is not actually visible in the track when everything is back in place. I went from about 4 inches from the top to almost the bottom of the window frame. It seems to just put enough pressure on the window th stop the rattle.
I'll update if there are any issues!
Update- It seems to have helped. I did see further improvement by adding the same weather stripping to the front of the window frame. Hope this helps.
Old May 9, 2009 | 07:40 PM
kevvur's Avatar
They make you put a small strip of this stuff into the run channel when you're installing the rear window visors.
Old May 9, 2009 | 08:48 PM
runbikerun's Avatar
Yea, Same concept.
Old May 9, 2009 | 09:13 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
great idea. waiting for your final results.
+rep
Old May 9, 2009 | 09:39 PM
runbikerun's Avatar
So far it is working great. We had a really windy day and no rattles!
Old Feb 18, 2013 | 06:37 PM
MEATBABY's Avatar
Old thread, but a great fix. Can't believe it took me this long to search for anyone who had solved this problem. I did it yesterday and used the exact same material pictured by the OP. Found it was too wide and too thick though, made the windows roll up and down very slowly and sounded like it was hard on the window motor. Cut it into narrower strips and thinned it and that seemed to do the trick.
Old Feb 18, 2013 | 06:49 PM
Wafulz's Avatar
dear lord thank u for this i did the window visors one but did not do shit so now i will try this thanks sooooooo much!!!
Old Feb 19, 2013 | 10:46 AM
FitStir's Avatar
Thumbs up
Good fix for window rattling...
Can't believe I never saw this before... thanks for bumping the thread.
Old Apr 13, 2023 | 07:24 PM
myspacerocket's Avatar
Tried this and didn't help much. Was going to get the window motor and assembly replaced and dropped the car to a mechanic. To my surprise, they solved the problem by just realigning and maybe tightening the driver's door without replacing anything at all. The rattle is completely gone now! So may be worth asking for that at your service shop.
Old Apr 16, 2023 | 10:04 PM
Pyts's Avatar
can check another thread called: window motor and regulator assembly replacement... yada yada. although focuses on performing the service necessary to remedy the window rattle, it also shows components and more or less explains the nature and origin of the vibration. if you go to a shop, window motor and regulator assy. is what they'll replace. Honda may do just the regulator assembly.
regardless, if they do both or just the one your problem will be resolved. It may well come back in time, but only if fasteners loosen or the part fails again, or if a non-dealer mechanic installs a poor quality regulator assembly (the whole window lift mechanism).
Old Apr 17, 2023 | 05:26 AM
That's great, thank you for your comment 👍
Old Apr 17, 2023 | 08:57 AM
Pyts's Avatar
You're welcome
That weather stripping idea isn't bad though and it would make sense to keep the plastic guide piece that holds the window glass to the single central rail upon which ithe window travels from breaking in the future. (will still wear out to be slightly loose from repeat usage.)
you know, so long as one was mindful fitment, so as to avoid straining the window motor or triggering its finger saver safety shut-off. And... if one lives in a place that gets below 32°f.. if water gets trapped in there by the weatherstrip before a freeze.. i assume it would be bad in some way.
patm95
Jun 22, 2016 11:36 AM
Piyo2005
May 13, 2013 03:47 PM
RetroAttack
Oct 15, 2010 10:32 AM
Mezzozero
Jan 29, 2010 08:34 PM
Raaaaaaaaaay.
Nov 26, 2007 06:10 PM
