My V1 mount solution
Old May 13, 2009 | 08:29 PM
Stormtrooper's Avatar
this will be in stages as Ive not that much time to do it all at once...so here is step one(Finding a good solution for the mount)
Your V1 should have come with a Visor mount, if you have it simply put it on backwards, so the clip faces towards the cabin not away from it.
in the same spot that my finger is located put some double sided tape...this is so it does not move when you reach up to press the mute button...(there is lots of movement once you push the clip part into the headliner)
This is what it will look like from the back:
And this is the final product:
you should be able to run the wiring into the head liner, down the a pillar channel, and then down the weather stripping of the door, into the Fuse box....this will be part two of a three part series, more to come later.....
Old May 13, 2009 | 08:59 PM
TWGE08's Avatar
Nice, now I know where to put mine when I get it
Old May 13, 2009 | 11:32 PM
reako's Avatar
Looks great so far! I know it's probably a lot smaller than it looks in the pic. This will be great for those that own a V1 and want to hard wire...personally I have a $100 'Cobra special'...don't think I could ever plunk down $400-$500 bucks for a radar detector. But hey, more power to ya man, and thanks for sharing your install pics!
Right now I have mine stuck on top of the center console using 3M velcro strips, and the wire running down to 12V all trashy like.....I really need to fix that!
Old May 14, 2009 | 12:24 AM
FitStir's Avatar
You could wire it to the maplights like Roger's Fit did in this thread --->https://www.fitfreak.net/forums/2nd-...me-lights.html
Originally Posted by Roger's Fit
I soldered my radar detector wire at this point as a extra bonus:
Nice location btw. +reps
Old May 14, 2009 | 12:27 AM
abu's Avatar
abu
isn't the radar detector now facing the black dots on the windshield? Wouldn't this hinder the V1's ability to detect? Thanks. Just got the V1 myself.
Old May 14, 2009 | 04:44 AM
moegenki's Avatar
I recommend placing some foam where the clip touches the headliner backside to absorb some movement/noise (it also aims the V1 more level to the horizon as opposed to upwards). The V1 also sort of rattles with the visor mount with moderate bass/road vibrations too so some dampening material between the unit and mount works wonders.
Then again this was all on a GD3 so ymmv.
Old May 14, 2009 | 11:59 AM
to the OP - um, that idea's been floating around for a long time... in fact, on my MINI my V1 is clipped to the ceiling.
Old May 14, 2009 | 03:26 PM
Thanks, I guess I thought I would share, if it helped anyone who hasn't been floating around as I have not. as it stood the suction cups had issues with the dots in that area, so I thought this was the better way to go but I assume so did everyone else...
Old May 14, 2009 | 03:27 PM
from what I can tell the sensor is a bit below, I guess we will find out once I get tagged by radar
Old May 14, 2009 | 03:30 PM
Im not sure how the Cobra does Im sure its a great detector, bu twhen I got my V1 I had an S4, and I needed it. 400 may sound like a lot but Ive been saved many times from speeding tickets over the years and its paid for itself a few times over now. The V1 is rated pretty High I think only a few others compete with it...and like I said its already been finacially beneficial...
Old May 14, 2009 | 03:33 PM
SWEEET thanks for the 411 I will consider this as an alternative to running all the wiring...it seems like a better solution.
Old May 14, 2009 | 04:48 PM
Rubba Burna's Avatar
HID Addict
im getting the V-1 in about a month, and ive been lookin around the car as to how to hardwire it, and its obvious the a-pillar is the only way =\ idk wat it looks like under the panel, but i dont want the wire to interfere with the direction of the deployment, should i be concnered about this...?
Old May 14, 2009 | 04:49 PM
keep the good ideas coming!
Old May 14, 2009 | 05:00 PM
Alpha Zero's Avatar
I just used some clearbra material and put it over the dots. You could probably use a small piece of tint also. Then suctioned my radar to that. That would also work for all radar detectors, as I know my Passport doesn't come with a visor clip.
Old May 14, 2009 | 05:03 PM
are you taking about the airbag under there?
if so, dont worry you'll be slapped with the a-pillar cover harder than by your V1 cord.
Old May 14, 2009 | 05:32 PM
HID Addict
lol yeah its about the airbag, but your right, i should be more worried about the panel :P however, by any chance, would the cord defelect ro change the direction of the deployment? like would it pop down/out somewhere it shoudnt be?
Old May 14, 2009 | 05:35 PM
think of the airbag as a gernade. it literally EXPLODES open into your face. your little phone wire is not going to divert its trajectory. if your wire doesn't tear apart, your V1
will probably fly off its mount and knock you out.
Old May 14, 2009 | 05:46 PM
HID Addict
lol yeathat will encourage me to mount my V-1 there :P but thats how its going to be now ;] 30 days tilli mount it GRRR wanna speed alreadi heh
Old May 14, 2009 | 05:53 PM
well, i dont encourage speeding on public roads. my V1 is a conversation
piece on my hobby cars. i got it as an accessory cause it's just frikken cool
to watch the arrows.
i rarely use my old passport in my FitS or FitSW. only when i
go to new areas since some places have those 55mph zone
to 25mph in like 10yards and cop hiding behind a barn like
in those duke of hazard shows. so frikken cheezy i tell ya.
Old May 14, 2009 | 06:26 PM
HID Addict
public roads you say? its more like a asphalt trail, single lane ALLL the way to the high way -.- no broken middle lanes, you'll be lucky to speed on these public roads. how ever, the side roads are emtpy ;] i speed on the side road to my house everytime, not like a maniac tho
ChuckDustin
Apr 12, 2019 12:47 PM
allmotormark
Oct 10, 2014 01:16 PM
mxl180
Sep 1, 2014 11:37 PM
TofuShop
Jul 25, 2014 09:15 PM
gladel
May 19, 2011 03:47 PM
