GD springs in a GE
Old Jun 1, 2009 | 09:05 AM
Lek's Avatar
Lek
GD springs in a GE
It was brought to my attention today that GD springs may fit in the GE and lower the car about 20mm.
I know it does not seem like a lot, but it would be perfect for anyone wanting just a slight drop because of body kit or bad roads.
I quess if the top and bottom coils and the K are the same they should be OK. It would then be up to the length of the spring.
Has anyone tried this or have access to compare the GD & GE springs.
Old Jun 1, 2009 | 10:31 AM
awptickes's Avatar
If this is true, this would be perfect for me. I don't want to use non-OE stuff, because it will put me into a modified class in autocross.
Old Jun 1, 2009 | 11:40 AM
Benggolf's Avatar
Cool GD Springs in a GE
Lek, if you get to swap your OEM GE springs with those from the GD...let us know how the car handles after the mod.
Just a word of caution: make sure the person who is installing the springs knows what he is doing and make sure there is no binding in any way.
Suggest you do not cut the bump stops.
Will be waiting for the photos and your write-up.
Old Jun 1, 2009 | 11:43 AM
runbikerun's Avatar
Please keep us updated on this one. Anyone know what the spring rates are?
Old Jun 1, 2009 | 01:06 PM
vinn's Avatar
I dont think it will work D=
Old Jun 1, 2009 | 01:48 PM
dela's Avatar
GD springs do fit in the GE... there are pictures somewhere on the board with a GE on stock GD springs.. search button i guess... and from what i remember someone from either thailand or some other south asian country has aftermarket GD springs on their GE
Old Jun 1, 2009 | 01:50 PM
awptickes's Avatar
Keep in mind that Honda used the same springs on the civic from 1988 to 2000. It's not that far-fetched that they'd do it again.
Old Jun 1, 2009 | 02:03 PM
BakedCookies's Avatar
They didn't, the spring rates are totally different, GD springs on a GE will make the rear sag and bottom out constantly.
Old Jun 1, 2009 | 02:04 PM
awptickes's Avatar
K. Good to know.
Old Jun 1, 2009 | 08:58 PM
Lek's Avatar
Lek
I know that the GE has more weight on the front that's why Honda recommends 33 psi in front tires.
Actually, the rear of the GE is higher than the front. I wish there was a way to reduce the rear springs only by 10mm, this would balance the car out and make it look much better.
The Mugen Suspension kit lowers only 20mm and desined to go with their body kits, but hard to find in any country apart from Japan.
Old Jun 2, 2009 | 10:25 AM
teamfit's Avatar
i tried it b4 , i have an g.d and an g.e , the stock gd springs is shorter by an inch , take note lek ( front only ) i have a sound set up at the back so i didnt need to change the springs anymore ,
Old Jun 2, 2009 | 09:58 PM
Lek's Avatar
Lek
Thanks teamfit, So the top and bottom of the coils must be the same size if they installed OK.
Is there any bounce or noise on the front end.
Old Jun 3, 2009 | 10:07 PM
teamfit's Avatar
yes there the same in top and bottom , no noise and bounce .
Old Jun 3, 2009 | 10:27 PM
Lek's Avatar
Lek
So, what did you do with the rear. If you didn't change them, too, the car must be very high on the rear.
Old Jun 3, 2009 | 10:47 PM
Tork's Avatar
Lek I think he is saying he has heavy speakers and amps in the rear with the weight of that bringing it down
Old Jun 3, 2009 | 11:06 PM
Lek's Avatar
Lek
Oh, I get it now. A SOUND SETUP. Where I come it means Very good. Sorry.
Old Jun 30, 2009 | 07:50 AM
Lek's Avatar
Lek
I have just been looking at the Tanabe DF spring Rates and the GD F 3.1 / R 4.9, but the GE F 1.7 / R 2.0. Why such a massive difference in spring rates between the GD & GE?
That should means stock springs should have the same percentage spring rate difference as Tanabe make their springs slightly above stock.
In theory, GD springs will lower the front of the GE 25mm with a stiffer spring rates which should give a better ride with less sway and body roll.
pearl
Jan 15, 2016 03:33 PM
Maty J
May 19, 2013 01:15 AM
fitisbamf
Jun 13, 2010 01:49 PM
kiggs
13
Apr 28, 2010 10:12 PM
Spaded
Mar 29, 2010 03:10 AM
