mudflaps on a sport...
Old Aug 4, 2009 | 01:42 PM
jnesselroad's Avatar
hey, i know the factory mudflaps don't work on the sport model, due to the sideskirts for the front, and the rear bumper shape for the rear set. has anyone actually purchased a set though to see if you could just dremel out the correct shape and still attach them? i'm pretty sure flaps are only about $45 on eBay, and i was going to try it, but thought i'd ask if anyone else had first.
Old Aug 4, 2009 | 01:47 PM
Vanct's Avatar
Heh, you may as well raise the fit 10" if you're going to add those.
Old Aug 4, 2009 | 01:49 PM
well, for now mine's still at stock height, so it IS 10" higher than it should be. i just like the look of mudflaps. always have. plus, they only sit about 1/2" below the bumper.
Old Aug 4, 2009 | 02:11 PM
secondspassed's Avatar
It looks pretty good if you remove the (rear) sport lip, then you can install the OEM mudflaps. Someone's done that around here...
Old Aug 4, 2009 | 07:57 PM
FitStir's Avatar
I've been waiting for that answer for a while... I've also thought that maybe using a Dremel one would be able to make them fit... but I haven't tried it yet.
Old Aug 4, 2009 | 09:20 PM
if you try it, lmk. if not, i'll probably buy a set next month and try it myself.
in case it's not real well known, i was doing some searching on here and found that the sport rear bumper is the same part # as the base rear bumper, so the rears "should" fit without modification.
Old Aug 5, 2009 | 05:57 PM
FitStir's Avatar
Unfortunately it's toward the end of my long list of mods still to do... Probably right before the sunroof
I still have to install some JDM parts I've had since Jan., but I'm waiting for another shipment from Japan to install them all at the same time...
I had asked the same question months ago, and no one knew if it could be done... I was also thinking about just removing the side skirts, but I'm not sure how that would look.
So I guess who ever gets to it first post back experiences on it.
Old Aug 5, 2009 | 10:14 PM
vinn's Avatar
I believe the rears should fit but the fronts you dont get the clearance due to the side skirts
steezo_
13
Dec 2, 2019 03:37 AM
GinoLicious
Mar 21, 2015 02:04 PM
ikutoisahobo
Apr 3, 2014 02:31 PM
mike410b
May 26, 2013 09:28 PM
UncleDaddy
Mar 26, 2013 11:04 AM
