PC Card Problem - 2009 Fit / Nav
Old Aug 6, 2009 | 11:50 AM
pheff's Avatar
I am trying to use a PC Card in the Nav radio for music.
I am using a Viking 32 Bit 5 in 1 adapter with a Sandisk 1.0 Gig SD card.
The card is formatted for FAT32 and I just copied mp3 files straight over to the card.
When I insert the adapter into the Nav radio, I can't close the front panel - the radio beeps three or four times. The only way to close the front panel is to remove the pc card adapter.
Any suggestions?
Thanks,
Old Aug 6, 2009 | 01:06 PM
Epoch's Avatar
While I hate to say "check the manual", they state that the Navi unit has a problem with PCMCIA adapters that support a broad range of memory types (Because each adapter class registers as a different logical drive, it could easily end up confusing the head unit).
What I would do is look for a straight SD (or SD/MMC) PCMCIA adapter. I bought some generic one off of ebay, and it's working great.
Also, google Panasonic's SD formatting utility and use that to format the SD card: That's the best way to guarantee a 100% compatible Fat32 format.
I also found out that it's best to swap the PCMCIA adapter or card when the car is off, as sometimes the headunit needs to "restart" when you turn on the car.
Old Aug 6, 2009 | 01:45 PM
pheff's Avatar
I know - being a guy I like to figure this out without the manual but I finally went to it. Doesn't give any specific info on the adapters or cards or errors. The great line in the manual is "not all cards work with this unit" - where are the specifics? I'll see if anybody else posts otherwise I get in touch with Honda.
Thanks,
PG
Old Sep 21, 2009 | 11:02 PM
FITMugen's Avatar
The easiest way to play musics in Hoda Fit is dump your MP3 into a USB drive and connect it to USB connect in your FIT. I have 500GB USB drive connect to NAV. You can listen to it from NY to CA without repeating a single song.
Old Sep 21, 2009 | 11:27 PM
reako's Avatar
Yeah, I have a 32GB Kingston flash drive setup with mine. I agree it's a relatively inexpensive and convenient way to get your music in the Fit. My folders take a bit longer to load than I would like (sometimes they won't load at all), the track titles can take a while too. Does your 500GB drive do this? What make/model drive are you using?
I would love to have a search function for my music collection...that's the one benefit of utilizing the PC card function. Although there are significant size limitations, at least you get a search function! Guess I need to upgrade my head unit some day.
Let us know what specific PC card setup ends up working best, I would like to try this out sometime.
Old Sep 21, 2009 | 11:35 PM
reako's Avatar
Can you provide a link to the exact product you purchased to get it to work? Great info here so far, thanks man!
Old Sep 21, 2009 | 11:52 PM
FITMugen's Avatar
Toshiba USB 2.0 Portable External Hard Drive - hard drive - 500 GB - Hi-Spe
Mfg. Part: HDDR500E04XL | CDW Part: 1834403 | UNSPSC: 43201803
Go to CDW - IT Products and Services for Business
This is what I have in my FIT.
Old Sep 22, 2009 | 03:20 AM
reako's Avatar
Cool, thanks for the detailed info. Looks pretty slick, and the built-in shock protection is a bonus. $89 shipped from Amazon: Amazon.com: Toshiba 500 GB USB 2.0 Portable Hard Dive HDDR500E04XL (Liquid Blue): Electronics
Can someone provide similar details for a PC card setup that is known to work? I may try out one of these sometime soon as well.
Old Sep 22, 2009 | 05:07 PM
FITMugen's Avatar
Please check this one out. It cost ~$5.50.
PCMCIA Adapter for Honda Civics & Fits with navigation - eBay (item 280400388077 end time Sep-26-09 17:23:01 PDT)
I bought one and put 1GB SD into it and it worked pretty good. However, I changed it to USB due to storage capacity, 1GB VS 500GB.
Ductapemaster
Dec 3, 2014 04:09 PM
embarkadero
Aug 24, 2009 11:13 PM
tanstaafl.
Dec 13, 2008 08:18 PM
barams
Dec 1, 2008 02:13 AM
FitInAugusta
May 12, 2008 01:56 PM
