Something weird happened today to my Fit
Old Nov 17, 2009 | 08:43 PM
Red 05's Avatar
Question Something weird happened today to my Fit
Just to point out, I'm smart enough to know not to fill up my car while the engine is running, and I tighten the gas cap down and check it every single time. Now, on to my story.
I get in my car at school today and crank my car over. As I buckle up, the mini screen in the dash flashes these three words:
Check
Fuel
Cap.
I think well wtf? I get out and check it and just like I suspected, it's on good and tight. I had to go to another class across town, but decided instead to go straight to the dealer, since I figured if there's nothing wrong with what I normally do, something is up. I get there, they take me in, I wait around 30 minutes, and they're finished. Instead of fixing something or telling me what went wrong exactly, they reset the code(s), warn me not to do this again or they will charge me, neglect to tell me exactly what went wrong other than insisting that I was filling the car while the engine was running, and continued to completely ignore my repeated efforts to assure her that I do indeed know not to run the engine when refueling, and tells me this happened because I was running the engine.
The only thing I could get out of this Marlboro-riddle sap was that the car threw two codes, one of which was a "Mass Obee-vee senser" and the other was camouflaged with more menthol-laden coughing. I was fed up and I wanted to go home, so I didn't ask her to attempt to repeat herself.
I appreciate that I didn't have to pay, this once but what gets me is that I'm treated like a complete idiot.
/rant.
Now, has anyone else had this happen?
Old Nov 17, 2009 | 09:09 PM
Committobefit08's Avatar
Check
Fuel
Cap.
/rant.
Haven't had it with the Fit but had it once with the tsx.
Similar issues happen with other tsx's. Its something to do with the gas fumes and drops in outside ambient temperatures. All I did was retighten the gas cap and the light will reset itself in a couple days. Don't know if this is the same instance but this is what it sounds like. Here are the stories...
http://tl.acurazine.com/forums/showthread.php?t=738498
http://tsx.acurazine.com/forums/showthread.php?t=675212
Old Nov 17, 2009 | 09:11 PM
Btrthnezr3's Avatar
Hmm...never had that happen. Can't believe the dealer was such a dew. I'm sorry dude. Hopefully it won't happen again!
Old Nov 17, 2009 | 09:14 PM
runbikerun's Avatar
My fit did the same thing a couple weeks ago. I had to take the gas cap off and put it back on then restart before the light cleared. Just tightening the cap didn't help at all.
Old Nov 17, 2009 | 09:32 PM
Red 05's Avatar
Thanks alot, that makes me feel better that I'm not the only one with a Honda/Acura problem like that. What gets me is that they didn't offer to replace anything, and assumed I was just some stupid idiot who can't operate a gas pump. What I probably should have done was wait a few days and see if it went away, because we did have a pretty substantial temperature drop over the past few days.
Old Nov 17, 2009 | 09:57 PM
Shockwave199's Avatar
This is interesting. It hasn't happened to me yet, but I don't turn the engine off when filling up. I shall do so now though!
Dan
Old Nov 18, 2009 | 12:44 AM
Virtual's Avatar
Dan
Wow! Haven't you seen signs like this at the pumps?
Old Nov 18, 2009 | 12:56 AM
Really- signs? I keep the car running and light up a nice big fat cigar every time I fill up. I even strike some flint sticks just to make it interesting.
Yes, I got lazy with the Fit. I had a '97 Caddy that was REALLY picky about shutting down for fill up. It would throw a code pretty easy for that. I will shut the Fit off like I should.
Old Nov 18, 2009 | 01:06 AM
RandomKoko's Avatar
This is what you do, turn on the engine, let it run for a 30 seconds. Open the gas cap while the engine is running, "yes open the gas cap" let it open for 10 seconds. Then turn the engine off while the gas cap is off, be sure to remove the key. Close it with the cap. Then start the engine, after 5 seconds it will disappear.
Good luck. It works for me, lets hope it works for you too.
Old Nov 18, 2009 | 11:43 AM
Red 05's Avatar
I'd rather this not happen again to my car, but I'll keep that in mind if it does.
Old Nov 18, 2009 | 01:24 PM
BlackUp's Avatar
My car did this 3 or 4 times in its youth. I had a scangauge back then and just cleared the codes myself. Ignore it and I bet it'll go away. Screw the dealer and buy your own code reader. Or just go to autozone, and they will read your code for free. Sounds like your dealer sucks.
Old Nov 18, 2009 | 02:06 PM
cd4ag's Avatar
This happened 2 me about 2 weeks ago aswell. The car hadn't even gone for it's 1st fill up so it was just some other weird issue. Retightened the filler cap 'n it went away after a day.
Old Nov 18, 2009 | 02:58 PM
if there is a DTC, just clear it using a OBD2 scanner and see if it reappears.
if it does, clean the gas cap's seal and see if that helps. if not, take it to the dealer and get a new cap.
Old Nov 18, 2009 | 09:29 PM
Ultrawolf's Avatar
Old Nov 18, 2009 | 09:33 PM
Gbaby2089's Avatar
don't worry it's not only Honda/Acura my mom's impala had the code reset multiple times, and they tried 3 gas caps from Chevy before we just got rid of it (that wasn't the only problem with it)
TrippKnightly
Jan 9, 2013 12:48 AM
qbmurderer13
Nov 19, 2009 09:56 AM
docjim2
Dec 28, 2006 05:06 AM
eyedryve
Sep 10, 2006 09:20 AM
Tomh
Jul 2, 2006 09:35 PM
