Panic alarm went off randomly,...has it happened to you?
Old Nov 14, 2018 | 10:56 AM
Kyle05STi's Avatar
My alarm kept going off last winter. After some googling I found that Honda hood latch sensors have a tendency to fail. I removed the sensor, packed the connector with silicone grease and wrapped it in electrical tape. The sensor sees the hood as "closed" when the circuit is open so unplugging the sensor permanently opens the circuit. No issues since.
Old Nov 14, 2018 | 12:38 PM
adamnnn's Avatar
mom pretty sure my problem is in the trunk though, since the trunk light won’t go off.
Old Apr 9, 2019 | 09:15 AM
ANGST's Avatar
kyle if you are still here , did this fix work 100% ?
Old May 20, 2019 | 10:54 AM
Kyle05STi's Avatar
I had to reset my password to get in but I'm still around. My alarm has not gone off since. The issue was 100% a failed hood latch sensor.
Old May 20, 2019 | 10:59 AM
ANGST's Avatar
Thanks, mine has been good since I unhooked it
Old Jun 8, 2019 | 02:46 PM
Atomike's Avatar
Seeing this issue too. Rather than try to fix my hood or hatch connections (no idea where to look, or what I'd be looking for), I think it would be easier for me just to remove a breaker. Does anyone know which one would control the alarm system? Or maybe I can't do this for security reasons?
Old Jun 8, 2019 | 03:16 PM
Red 05's Avatar
The quick answer is to disconnect the horn behind the driver's side headlight. It does not sound when you press the horn, that's a separate horn. If you'll give me a few moments I'll find the method to access the latch on the hood in the service manual.
EDIT: I'm attaching the page for removing the top of the grill and the guide to remove the hood latch. If you need more or something different let me know.
Old Jun 14, 2019 | 11:15 PM
Icirus's Avatar
Its probably been said already but rip out the hood latch sensor.. Red 05 has the right idea.
I did that and it fixed my problems
ALopeZ27
Nov 18, 2018 02:25 PM
Brain Champagne
Dec 10, 2010 08:20 PM
Blackbeard
Nov 8, 2010 11:52 AM
teebar47
Sep 21, 2009 11:57 AM
cph81
Feb 21, 2008 07:48 PM
