Wheel Stud Corrosion!?
Old Feb 6, 2010 | 01:29 AM
Lyon[Nightroad]'s Avatar
I was doing my first rotation today and ran into an odd problem. Drivers rear wheel came off real easy. Front wheel on the other hand was damn near welded on. Took a few blows from a rubber mallet to free the wheel from the hub. Upon closer examination I noticed a fine dust fell out of the lugs and there is a fair amount of corrosion on the stud. This is the first time I've remved the wheel and I've never had that much difficulty with wheels 10yrs older. Is there any compound I can use to combat this? Can I safely use teflon tape? Any ideas?
[IMG][IMG]http:http://img132.imageshack.us/i/imagegf.jpg/[/IMG][/IMG]
Old Feb 6, 2010 | 02:21 AM
Virtual's Avatar
Here's your pic:
Use a steel brush to clean the hub:
Apply anti-seize compound on the center of the hub to prevent the rim from sticking:
Old Feb 6, 2010 | 03:27 AM
Ah thank you! I've got some nickel-graphite anti seize laying around. I guess on my previous vehicles I was rotating every 3k and never had this problem.
Old Feb 6, 2010 | 08:26 AM
specboy's Avatar
When I did my Rotors or brakes on my cars, It took me a number of smacks on the tire to get the wheels off. Usually the fronts are more stuck on there. Looks normal to me from the photos. The anti seize is a good solution.
~SB
SilverEX15
Jan 20, 2019 11:30 PM
Phoenician
Oct 5, 2016 12:08 AM
Swimmer Boy
Feb 16, 2009 10:56 AM
Burbio
Oct 19, 2008 06:17 PM
boyetssilverfit
Feb 13, 2007 08:24 PM
