Loose Hood?
Old Mar 3, 2010 | 01:09 PM
3suom's Avatar
Loose Hood?
I've noticed on my car, with the hood fully closed, that it does not close tight and there is a little bit of play. Is this common on the 2010 Fit or a defect?
Thanks for the help!
Old Mar 3, 2010 | 01:33 PM
neil patrick harris's Avatar
mine is tight like a tiger.
Old Mar 3, 2010 | 02:33 PM
whaap's Avatar
Mine isn't here right now to look at but if you have two rubber stops below the front of your hood when it is closed it's possible they are adjustable (up).
Old Mar 3, 2010 | 03:38 PM
Selden's Avatar
Screw-adjustable bumpers are the norm. You can experiment with screwing them out to put a little pressure on the hood. If this raises the edges of the hood above the fender line, you can probably adjust the latch.
Old Mar 4, 2010 | 08:02 PM
Clarkemode's Avatar
Yea, mine is loose too..Just thought it was supposed to be like that....
Old Mar 10, 2010 | 02:00 AM
tyrannyofsouls's Avatar
mine is also a bit loose on the 2010
Old Mar 10, 2010 | 04:21 AM
555sexydrive's Avatar
Just went outside and checked mine to see, not really any play, but the center of the bonnet does kind of wiggle ever so slightly (barely), but the sides don't budge at all. There are definitely 2 rubber bumpers you can raise up and down. Maybe just raise them up gradually and find what works best.
benmaggoswd1
Mar 19, 2018 10:20 AM
pandayun
Dec 21, 2011 04:12 PM
CrystalFiveMT
Dec 25, 2009 01:48 PM
mozarwasagenius
Dec 23, 2008 05:31 PM
Elle
Aug 12, 2005 11:34 PM
