Oil Changed at 4,062 Miles. Potential Damage?
Old May 17, 2010 | 10:24 PM
  #81
sr.sedan's Avatar
manufactuers only sell you a car that going to last you five years if you go by the maintance minder
Old May 17, 2010 | 10:36 PM
  #82
SilverBullet's Avatar
Gas and oil has come a long way your car will last longer if you go by the minder. If you change the oil at every 3k the additives dont even start to work and the moly on the pistons will drain out before it coats the engine. There is no sulphur in the oil and gas now so there is a longer drain period. With sythetics you could almost go indefinitely with filter changes.
mizike
Apr 25, 2018 04:16 PM
kremkaos48
Feb 18, 2018 02:03 PM
BLXFITTY
Sep 7, 2014 09:25 AM
carolina_cruising
Nov 13, 2013 07:09 PM
bugsfit
Aug 3, 2013 03:53 PM
