yakima feet
Old May 22, 2010 | 03:06 PM
AtticusFit's Avatar
yakima feet
anyone got any pic of the mounting of their yakima mounting feet, my Q5 clip dont seem to mount close to the door edges.
Old May 22, 2010 | 04:09 PM
txmatt's Avatar
Remember that one 30" dimension is between bar centers, not to the edge of the feet like the front measurement is.
Old May 22, 2010 | 04:32 PM
get_FIT's Avatar
how much was the rack ?
Old May 22, 2010 | 04:53 PM
AtticusFit's Avatar
yeah but the Q clip looks like if sits flush to the metal on yours mine doesnt
Old May 22, 2010 | 04:55 PM
AtticusFit's Avatar
i paid 360 for mine if you need one
Old May 22, 2010 | 09:51 PM
AtticusFit's Avatar
bump.......
Old May 23, 2010 | 08:56 PM
AtticusFit's Avatar
just one person has a yak rack?
Old May 23, 2010 | 10:41 PM
PaFitter's Avatar
Are you sure your measurements between feet on the bar is correct. Locating them closer or farther apart will affect the angle of the clip,any clip. The picture looks pretty close to my set up. Also make sure the bar spacing measurements are correct. The angle of the roof line changes,and also will affect clip angle or height from door edge. If you take your rack off and on like I do,and to get the rack back on exactly the same place every time,take a piece of electrial tape as long as the clip,and place in the inner door edge once the rack is placed exactly . Line up the tape with the clip edge and clamp. I haven't changed any adjustments to bars or tension adjustments since I mounted the rack last year when I bought the car. The tension is snug,but not over tight to dent the roof,secure,doesn't work loose or need readjusted. I have thousands of miles hauling 2, 15' canoes without issues.
PaFitter
Old May 24, 2010 | 07:31 AM
specboy's Avatar
I've got a yak Rack but don't have the clips yet (and I bought it 10 years ago) so I can't as of yet comment on the FITment of it yet.
oh god.. .it's early.
I hope to pick up the clips soon.
~SB
Old May 25, 2010 | 09:58 AM
nothing's Avatar
No pics, but mine looks very similar to the GE pic posted. One thought, as mentioned, check the spacing between the two towers on the bar. The measurements for the rear bar for the GE Fit included in the Q-clip package were incorrect. I orignially installed it using the spacing indicated in the Q-clip package and the clips would not sit flush. I checked Yakima's website and noticed that the distance between the two towers on the rear was different (closer together). When I changed the spacing the clips fit flush as they were meant to.
flipbizkit
Jul 14, 2020 09:34 AM
thewwkayaker
May 14, 2015 03:37 PM
rebelee
Dec 21, 2013 01:57 AM
Grunthaner
Sep 11, 2013 05:51 PM
bwb
50
Oct 16, 2009 10:39 AM
