Hate/Hack the USB Audio Interface?
Old Dec 7, 2010 | 02:07 PM
drumsauce's Avatar
It would be IDEAL if APPLE partnered with an automaker (Honda? ahem) and integrated Ipod functions in the stock radio the way Microsoft did with Sync and Ford.
Ah, in a perfect world....
Old Dec 7, 2010 | 02:13 PM
LLLC1393's Avatar
Originally Posted by drumsauce
I too, like the integration of the USB cable with my Nav. Slow? yes. But I don't have a problem with the time it take to find an artist and play. Or, I just find a playlist that I want to listen to. Although it isn't perfect, compared to other stock units on other cars, this one does a decent job.
Agree with previous posters for your solution, OP:
1. replace head unit with one DESIGNED SPECIFICALLY for an Ipod (expensive, but it would solve ALL of the problems you listed)
OR
2. use an AUX cable and control the functions from your Ipod. A little less ergonomic, but would also eliminate many of the complaints you listed.
Good luck!
A replacement head unit does not need to be expensive to do what he wants. He could certainly get the artwork on the display as well. Crutchfield is a great place to look.
Old Dec 7, 2010 | 02:29 PM
Vacca Rabite's Avatar
The USB/iPod interface was one of the selling points for me on the car. I commute a lot and listen to a TON of audiobooks.
After a week of trying to make it work as it is supposed to according to the manual, I am going back to the mini-jack input cable. As it is set up now, I think it is more dangerous to try and use this system on the road then it is to just use the iPod to get to what you want to listen to.
Also, be careful of disconnecting your iPod to choose what you want to hear and the putting it back on the glove box interface. Doing this jammed my iPod, and I had to wait until I got home to reset it. Frustrating.
Zach
Old Dec 7, 2010 | 02:40 PM
LLLC1393's Avatar
Yeah,then Apple updates the iPod and your car radio is not current. Apple loves to make changes that eventually force you to get new hardware. This system seems to work pretty well. It is FREE with the car. Ford Sync is a premium options that requires other options to get it. Just somethings to consider. All in all,my Fit has alot for the price. Now if Acura made a version...
Old Dec 23, 2010 | 11:27 AM
sixthj's Avatar
Free interface?
My Honda dealer wants to charge me $260 for the USB audio interface. What's up with that? Where can I find a cheaper aftermarket interface? This is a 2010 Fit Sport. The connection's there in the glove box, but I need this extra part to use it: 2010 Honda Fit - Accessory Detail - Official Honda Web site
Old Dec 23, 2010 | 11:35 AM
Ciggy's Avatar
For #4 if you hold the display button is displays the rest of the title. Figured this out just a few weeks ago!!!!!!
Old Dec 23, 2010 | 01:11 PM
LLLC1393's Avatar
I'm confused. YOur 2010 Fit SPort should have come standard with the USB audio interface int he glovebox. If it didn't,the dealer or Honda should upgrade you to it for free imo. Please clarify.
Old Dec 23, 2010 | 02:59 PM
blazej's Avatar
I'm happy with it, since I can use pandora through the iPod connecter.
Old Dec 23, 2010 | 05:45 PM
sixthj's Avatar
I'm confused, too! the dealer showed me the cord that is in the glovebox. It has a mini tip, such as comes on the end of a headset/earbuds. Then the dealer said to use it I need a USB interface to plug into that, and it costs extra. see link on the Honda site describing the part they want to sell me: 2010 Honda Fit - Accessory Detail - Official Honda Web site
thanks for your advice!
Old Dec 23, 2010 | 07:56 PM
sooznd's Avatar
You do not need anything extra--I have a 2010 Sport--you do need to use the ipod's usb adapter/charger and then plug into the Fit's usb cord. You cannot plug an ipod in directly.
I like the usb interface. The ipod controls are not the easiest & cumbersome if you have a huge playlist., but I also have songs that I copied to flash drives & love that you can do that as well.
Old Dec 23, 2010 | 09:09 PM
specboy's Avatar
Point your dealer to the 2010 info for the fit sport and show them it has a USB interface standard. take a flash drive with you and ask them where you plug it in. when they can't figure it out, have them show you on a new model. the sport & Base now both come with the usb port so any new fit will work. then ask them why your model doesn't have it when every fit sport was sold STOCK with the USB interface.
ANY AND EVERY fit sport should have a USB Plug for a flash drive. to hook up an ipod, you need to use the USB cable that came with your iPod. That part you are linking to comes standard on every fit sport. EVERY 2009+ sport... EVERY one. emphasize to the dealer this point.
If they can't figure it out... find another dealer.
~SB
Old Mar 23, 2011 | 01:50 PM
  #32
Morris's Avatar
Does anyone know what brand of Flash drive will work in the USB port. I find the details listed in the manual are not the information that is usually listed with the product. like FAT file and no security. Have been googling for hours trying to figure this out. thanks
Old Mar 23, 2011 | 05:05 PM
  #33
Brain Champagne's Avatar
Which brand? Probably all of them- I just got a generic 8 gb one from Staples, dumped 300 CDs on it and it's working fine. But probably can't require a password to unlock it. They cost ten bucks, no sense driving yourself nuts about it.
Old Mar 23, 2011 | 05:39 PM
  #34
TakeFlight's Avatar
Same here. Just bought the cheapest 16GB stick. Works fine.
Old Mar 23, 2011 | 06:19 PM
  #35
mhrivnak's Avatar
My current frustration is that I want to play audio content from my Android phone using the AUX in, and charge it at the same time from the USB cable. Doesn't work! For some reason, they are considered the same input by the head unit (NAV), and when something is plugged into the USB cable, it takes priority over the AUX in. Ugh.
Old Mar 23, 2011 | 06:24 PM
  #36
For five bucks you can buy something that plugs into the power port and has a usb on the other end.
Old Mar 26, 2011 | 05:51 PM
  #37
melpote's Avatar
Originally Posted by Irish4199
Just use the a $5 audio cable and connect your iPod to the audio input on the dash.
Now all your features work.
this isn't an option if you don't want to lose your battery over a long trip. I like the USB to charge while I listen. I totally agree with the OP. Unless I already have the artist/song picked out before hooking up to USB, scrolling through on the dash bites.
but...I am very glad that I have the USB hookup to play my ipod. I no longer have to lug around my cds, which is brilliant!
Old Mar 26, 2011 | 06:17 PM
  #38
specboy's Avatar
I think you can just press the Aux input button again and it will kick over to the headphone jack. I've had my flash drive plugged in to the usb port and had my wife play her ipod on the Aux jack. all I had to do was press Aux a 2nd time.
Edit - I missed it was the NAV that you have - I have the stock HU.
~SB
Old Mar 29, 2011 | 11:15 AM
  #39
Cowboy_Fit's Avatar
~SB
I wouldn't even give them the benefit of a doubt by asking them repeatedly. Just find a new dealer ASAP. If they are trying to scam you about a standard feature, which is also listed on the window sticker, then god only knows what else they would try to scam you on. Run and don't look back.
Old Mar 29, 2011 | 07:28 PM
  #40
Nukedog's Avatar
I just wished our USB would charge the Ipod like the one in my GMC
