rpm drop in 3rd gear
Old May 22, 2014 | 10:26 AM
  #41
mahout's Avatar
Originally Posted by Raouf
I drove out to Charlottesville Va last week to pick up a friends brother, he didnt believe me when i told him the fits slow, so i showed him...
i was in third gear and we were watching the rpms slowly creep up, when it hit 6,500 it then dropped to 6,000 then crept back
up to 7,000 where i shifted (obviously) and the whole time my foot was jammed to the floor, i tried it again and it did the same thing.
i NEVER ride at high rpms (especially in 3rd) so i never noticed this, has anyone else noticed this??
and dont worry, it was an empty highway
First, why did you hhave to shift when rpm reached 7000? Why didn't it upshift by itself as an AT would.
Second did you have ant change in elevation at the point it reached 6500?
It sounds like the rpm limiter worked and cut off. Have no idea why that could happen unless the engine suddenly had an increase in power required that wasn't enough to cause downshift..
Old May 22, 2014 | 10:28 AM
  #42
mahout's Avatar
As for slow; compared to what? How about a Fiat 500 not Abarth.
Old May 22, 2014 | 11:25 PM
  #43
sabawballs's Avatar
you mahout, you quoted a reply that was sent 2010
Anyway, it wouldn't upshift itself if its in the "S" mode and using paddles. It does downshift automatically though if speed are too low.
Not sure if its a limiter since it creeps back up and goes farther (7k).
Old May 24, 2014 | 06:08 AM
  #44
hotkey's Avatar
Originally Posted by sabawballs
But if its a normal behavior, why don't everyone here experience this? Or they just don't go to that limit? mehhh
Yup, most people who drive AT's don't rev to the limit. Those that do go auto-x, where the car mostly stays in M2, and rarely, if ever, sees redline in M3.
hmmm so if its a torque converter related, how can we eliminate this? and is it even possible?
Hmmm... it may be the torque converter. But i doubt. If it were the TC, it should happen whenever revs go up to ~6500rpm, in all modes, i think. But it only happens in M3 going to M4. But if it were the TC, we could try replacing it maybe?
Old May 24, 2014 | 06:15 AM
  #45
hotkey's Avatar
Originally Posted by lightyear22
I am seeing the same thing. My tuner believes is torque converter related. I am running an additional tranny cooler. Going to check the fluid and for leaks today. In the attached photo is the graph from 3rd gear pull and around 6K it drops. Rev limiter set to 7100. I am in a GD3, sorry
https://dl.dropboxusercontent.com/u/...2/IMAG0725.jpg
Hmmm.... interesting. Have you mentioned this to the GD folks? Their comments?
Old May 27, 2014 | 01:57 AM
  #46
sabawballs's Avatar
Thanks for the reply mate! Well it might be "normal" after all.. Hate it though when it happens since i know it can push faster if that does not happen. lol
Old May 27, 2014 | 03:29 AM
  #47
Goobers's Avatar
Okay so, Committobefit08 said (a while back) it happened to him in 4th gear also.
So I wonder... could it be a programmed logic?
Let's look at the details (or what I can recall anyway).
In D mode, the car revs up and shifts without the momentary RPM drop.
In S mode, the car revs up and shifts the first two times (1-2 and 2-3) without the drop, but does it in the 3-4 and 4-5 shifts.
Now, in S mode, the car is supposed to be able to HOLD RPM even up to redline, but that's only if you are actively using the paddle shifter ("Manual-S").
Since folks are getting "auto-shifts," it means they aren't actively using the paddles ("Auto-S").
It could simply be that the programming/timing is slightly different for the later two shifts in "Auto-S" mode as opposed to D mode (full auto). And that, in D or the early two shifts (1-2 & 2-3), the programming and timing were setup tighter.
Then again, could be something else entirely.
Old May 28, 2014 | 01:30 AM
  #48
hotkey's Avatar
When Gary of Sprintex noticed this behavior, he said that the throttle plate was closing slightly even though the pedal remained floored. The fix, if i understand correctly, was to not add timing at the top end of the rev range. But i don't know if the AT was in D or S or manual mode.
Hopefully, he'll enlighten us and tell us what we can do about it. Like buy the Sprintex Supercharger maybe?
Old May 28, 2014 | 07:16 PM
  #49
SprintexUSA's Avatar
Ours still does this consistently. Interesting to see it on other vehicles. They just might be doing something funky there at 80mph. Under normal conditions, you would be struggling to keep up at that speed anyway. I've noodled with timing and fuel up there and nothing changes. The mapping I'm running consistently adds 9 degrees of spark advance over 5200rpm. Kinda strange that it likes more timing under VTEC, but I'll go with it.
I'm listening to everyone's observations. Our blower has it's own thread. I don't spam forums, especially if I know I'm the new guy! Hopefully you find that refreshing . I did not grow up working on Hondas.
gdhi11
May 24, 2012 12:38 PM
dramagrl248
Apr 15, 2011 07:11 PM
Romulus
Sep 18, 2010 09:58 AM
fr_wilson
Apr 2, 2009 02:26 PM
danger69
Aug 31, 2007 10:00 AM
