"Thunk" from the driver's seat.
Old Aug 29, 2010 | 08:50 AM
phinegan's Avatar
Hi -
2010 Sport AT here.
Sometimes when I either corner or stop a little hard, I feel something in the driver's seat giving me what almost feels like someone in the back is kicking me in the lower back. It's almost as if there's some inside the seat shifting around and occasionally it "thunks". My not-wide wife says she feels it, too.
There's nothing looose under the seat, and as best I can tell the seat rail hardware is tight.
I'm going to have the dealer check it out eventually, but I'm curious if anyone else has experienced this, and especially if anyone know what the cause and/or solution might be.
Thanks -
Dan
Old Aug 29, 2010 | 09:13 AM
!bungle's Avatar
I've got the same problem. Even the front passenger seat in my 2010 Sport AT will do it if someone's seated there. It is my main pet peeve with the car, which I love otherwise. My thought was also eventually making the dealer check it out, as no amount of adjusting the seat makes it go away.
p.s. I'd edit "wide" to "wife" before she sees the post and thinks you're making a Freudian slip about the size of her ass... (heh-heh)
*** Edit ***
https://www.fitfreak.net/forums/2nd-...cking-fix.html
did a search, looks like a common problem and the solution has been found... I'll test it out and report back...
Old Aug 29, 2010 | 11:10 AM
malraux's Avatar
I had this. Just check the bolts for the seat rails.
Old Aug 29, 2010 | 11:17 AM
Krimson_Cardnal's Avatar
Been slight issues with seat rail bolts. Book says they should be torqued to 25ft/lbs. Might want to check em. Plastic covers pry/pop off.
Old Aug 29, 2010 | 11:18 AM
Black3sr's Avatar
The manual says there is a limit to what the seats will bear.
Page 35. Look it up.
fitbuddha
Apr 19, 2015 04:32 PM
Neros
Oct 22, 2013 05:56 PM
Neros
Aug 21, 2011 02:55 PM
Baxter
Jan 3, 2010 11:17 AM
jelliotlevy
Apr 30, 2009 06:01 PM
