GD rear end on GE
Old Nov 4, 2010 | 02:19 PM
Cl9lover's Avatar
GD rear end on GE
Has anyone tried to put the GD rear end on the GE?
I tried searching but no luck...
As some of you know I plan on running 16x8.5 +20 16x9 +14 wheels on my GE... I however cannot adjust the rear camber on the GE and was curious if anyone had simply swapped the rear...?
Old Nov 4, 2010 | 04:28 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
you would physically needs to look at both and take
measurements to find out.
maybe someone can post up GE measurements while someone
else posts GD.
Old Nov 4, 2010 | 05:18 PM
TheRealDooder's Avatar
are you reffering to the rear bumper or lip?
also to doe the rear camber, look in to shims you can adjust the camber i believe you can do up to -2 max. search engine is you're friend.
Old Nov 4, 2010 | 05:48 PM
Cl9lover's Avatar
Im talking about the entire rear suspension setup -
You cannot adjust the rear camber on a GE only the GD...
Old Nov 4, 2010 | 06:07 PM
i read somewhere that you can with shims... look more in to it, but im not 100% sure.
suspension yes you can, but the rear trailing arm and whole thing i doubt it, but try it out and let me know how it goes.
Old Nov 4, 2010 | 07:59 PM
JamesBizzle's Avatar
To my knowledge, you can't adjust the rear camber on either the GD or GE. As others mentioned already, look into shims or machine down your hub to compensate the negative camber you wish to run.
Old Nov 4, 2010 | 08:20 PM
Type 100's Avatar
The suspension really isn't all that different between GD and GE. The GE's is a more refined design but the guts are the same.
What I really mean is...no you can't adjust the rear camber on both. Both cars use torsion beam axles for rear suspensions. Shims are the only way to get very limited camber adjustment.
Old Nov 5, 2010 | 01:30 AM
drumsauce's Avatar
OP - I see where you are going. My understanding is that the GD has a bolt-on hub allowing shims to be used behind it, where the GE hubs are welded or pressed into the actual rear end assembly which means NO shims will work. Please correct me/give proof if i'm wrong...
Old Nov 5, 2010 | 09:02 AM
Cl9lover's Avatar
Thats what everyone keeps saying - So I figured, Ill just swap out rears... lol!
If I can shim the rear of the 09 its news to me... No camber kits appear for it and everyone says its welded.
Old Nov 6, 2010 | 03:59 PM
rhyneba's Avatar
The GE8 rear beam is one piece from end to end. The GDs have bolt on hub assemblies that can be shimmed or machined. I am working on mine now; we just got a new rack in our shop and my Fit is going on this week. My left rear camber and toe are out; I will probably have to replace the beam to correct it. I think it's ridiculous of Honda to have no other remedy than beam replacement to correct a commonly alignable issue... big bucks. I may apply some torque to the arm prior to replacement to see if it can be bent at all.
More as it happens...
b
Old Sep 26, 2011 | 02:22 PM
ohanahuichubbz's Avatar
any updates on this topic?? im curious to see if gd trailing arm can be swapped w ge.
Old Sep 26, 2011 | 02:24 PM
neteng101's Avatar
I was hoping to see images of a GD rear ending a GE based on the title.
Old Sep 26, 2011 | 02:57 PM
FitStir's Avatar
Originally Posted by JDM_DOHC_SiR
( JDM Rear Disc Brakes )
1) Right/Left rear disc, P/N 42510-TFO-000
2) Right/Left rear hub assy, P/N 42200-TFO-000
3) Right rear caliper assy, P/N 43018-TFO-000
4) Left rear caliper assy, P/N 43019-TFO-000
5) Right rear sensor assy, P/N 57470-TFO-013
6) Left rear sensor assy, P/N 57475-TF0-003
7) Rear Trailing arm assy, P/N 42100-TFO-N05
Why not just get a JDM GE8 rear trailing arm assembly? Or can you not adjust camber on those either? (not sure myself, maybe some one knows for sure)
Speaking of which anyone know approx how much the above parts to get rear discs would go for? give or take?
(I'm guessing price is why no one's done the JDM rear conversion yet?)
Old Sep 26, 2011 | 03:00 PM
op - um.... why?
acclude17
Oct 25, 2014 05:46 AM
paanta
Jun 24, 2014 03:47 PM
EMC2
Nov 17, 2011 10:39 AM
davela72
Sep 17, 2010 08:35 PM
blahx
Mar 19, 2009 02:07 PM
