Brake pads and Tires need replacing at 43k?
Old Nov 30, 2010 | 09:57 PM
BT53's Avatar
43000k...that's 26719 miles.
Old Dec 1, 2010 | 11:18 AM
Vacca Rabite's Avatar
Originally Posted by wskwong
If the Fit comes with 16" I don't see why it won't fit with a slightly bigger 15" tire. The only thing that I am worrying about is if the tire will pop off the wheel or something at highway speed, since it is a little wider than the original.
As to the 175 and 185 etc, so long as the wheel is the correct diameter, the width is not going to be an issue. With the 185 you will get a SLIGHTLY bulgier sidewall, a little more comfort, and a little less performance in the turns. Probably not enough to notice - especially since they are going to be snows which feel like mush compared to regular tires anyhow.
Each tire will have a sticker which will indicate the widest and smallest rim width it can be safely mounted on.
Old Oct 24, 2011 | 09:59 PM
jeon's Avatar
Apologize for the disturbance. Im on the same boat few weeks ago. I have now been through 2 sets of ceramic brake pad set from one of auto parts store online. They have a loud squeal only when I apply brakes and there seems to be a small loss of braking power. I run 37's but ran the oem pads for over 2 years. Anyway what brand of brake pads are you using?
timemachine
Jun 23, 2014 10:23 PM
SevereService
May 18, 2014 12:29 PM
Marrk
Mar 2, 2011 03:09 PM
TWGE08
Apr 5, 2010 11:20 AM
derekparker
Jul 15, 2009 03:13 PM
