squeaky suspension question
Old Nov 27, 2010 | 11:47 PM
spin out's Avatar
at about 20,000 miles i already noticed some light/limited front end suspension squeaking (unknown specific source). i'm currently at 24,000 miles. i can hear the squeaking when i go over my condos speed bumps at 15 mph. but no squeak at 10 mph.
i also hear it when backing out of my brother's driveway and a friend's driveway, which has a bit of a slope to it.
otherwise i generally dont hear it.
question: i dont plan on going back to the dealer until my next oil change, probably in March (another 3000 miles). am i risking anything by waiting? or should i address it sooner? the sheer fact i have any squeaking at 20,000 miles is annoying.
Old Nov 28, 2010 | 01:02 AM
Hootie's Avatar
No, you aren't risking anything warranty wise since this will be covered under your 3 year/36,000 mile bumper to bumper warranty. However, are you 100% sure that the squeak is coming from the suspension and not from the dash or some item inside the car? The dashes on Fits usually become quite squeaky when the weather begins to get colder.
Try having someone ride in and/or drive your Fit in those specific areas that you usually hear this noise. Have either you or them listen for the source of the noise from both inside and outside the car so you can find and confirm its location.
Old Nov 28, 2010 | 01:36 AM
spin out's Avatar
Originally Posted by Hootie
No, you aren't risking anything warranty wise since this will be covered under your 3 year/36,000 mile bumper to bumper warranty. However, are you 100% sure that the squeak is coming from the suspension and not from the dash or some item inside the car?.........
thanks for the response.
definitely not the dash. it's coming from around the wheels. i have all the windows down when i'm checking out the squeaking.
my sister's 1994 ford focus with 185,000 miles on it, which she bought from a friend for $1, after sitting outside for 1 full year, unused, doesn't even squeak. lol. ooofah.
Old Nov 28, 2010 | 11:17 AM
txmatt's Avatar
Mine has a squeak/scrunch from what sounds like the front suspension area when it's cold when going over large dips/bumps like speed bumps. Figured it's probably bushings or something but I haven't looked into it yet.
Old Oct 28, 2011 | 09:50 PM
jeon's Avatar
Sorry for the late in time reply but there are parts store online that cater ford suspension. On the other hand, you can actually ask for the TSB from the dealer so that you will not find difficulty with regards to the repair job.
Old Oct 28, 2011 | 10:21 PM
Vash's Avatar
my suspension squeaks sometimes too.. as if i had aftermarket springs or something
Old Oct 31, 2011 | 08:45 AM
12vltfrk's Avatar
i got the same issue, mine makes the noise from the uneven driveway to the flat road
Old Oct 31, 2011 | 12:21 PM
could be the swaybar bushings. if that was my car i would remove the bushing, white litheum grease inside and out of the bushing and assemble back.
make sure you grease between the outer bushing and the mounting bracket.
Old Oct 31, 2011 | 12:57 PM
Steve244's Avatar
Back in the bad-old-days I'd watch the alignment guys spray stuff on the control arm bushings of 1970 buicks to stop squeaks.
When I asked Honda during my last oil change to spray my Fit's front end bushings with something to stop squeaks they looked at me like a puzzled dog and suggested I have them replace the bushings, whereupon I adopted the puzzled dog look.
Some of this stuff in a hand sprayer should do the trick; "removes rubber squeaks in bushings and grommets." It's antifreeze with a bit of soap, so maybe mix up your own...
Old Nov 1, 2011 | 12:09 PM
you are aware today is year 2011...
Old Nov 1, 2011 | 02:19 PM
Steve244's Avatar
heh, and the product I linked is available online from amazon today...
Some sort of penetrating lubricating spray that does not harm rubber should be fine. They're not intended to need lubrication.
Old Nov 1, 2011 | 02:35 PM
Jodele's Avatar
First question; do you a Progress rear sway bar? If so, the bolts under the springs are causing the squeak. I’ve replaced my bolts with flat head M10 bolts. I had to drill countersinks for the heads in the lower spring seats. That cured my squeak.
If the noise is coming from the front, pick up your car and blow out any dust in the upper and lower spring seats…they are rubber. Then spray on some ArmorAll. You want to get it in between the spring and the seat. Do this for the front and the rear.
Old Nov 1, 2011 | 04:17 PM
Krimson_Cardnal's Avatar
Uppers are prone to this on many vehicles. I would go for a pure silicone spray. Any/all moving parts can squeak. No factory lube schedule/recommendations on the Fit.
Old Nov 1, 2011 | 04:32 PM
Jodele's Avatar
Silicone spray is a good idea! I didn't have any, so I didn't use it. You would probably have to do it less often with silicone spray. But hose out the dirt first!
Old Dec 22, 2011 | 02:41 PM
DarkHorse72's Avatar
Squeaking front suspension
My '11 Fit at 5k miles has developed front suspension squeak/scrunch going over medium sized speed bumps where I live. I have 3 speed bumps going out to the road so it is consistent and not the dash.
When the car was new, there was no noise going over those bumps. I'm rather gentle driving over it too..so its not like I hammer those bumps.
No sound from the rear...only from the fronts.
Anyone got this fixed and cured?
Old Dec 22, 2011 | 08:20 PM
monkeydave's Avatar
mine has started to do this now the weather is getting cold, it was quieter today almost went away because it is milder today, don't think it is anything to worry about, my car is a march 2011 with 6000 miles on
Old Dec 22, 2011 | 09:43 PM
oDDicAL's Avatar
This is the first year mine has started doing this, but it has been below or at/near freezing for most of the month. Mine's a 2009 with about 44k miles tho.
Old Dec 22, 2011 | 10:00 PM
doctorz's Avatar
Same here. 26k. Only squeaks on speed bumps under 40 degrees. Anyone had success with dealer or anyone fixing this?
azopelnut
Aug 20, 2018 09:49 PM
spin out
Dec 25, 2013 11:55 AM
mugenfit79
Jan 29, 2012 02:34 PM
denyko
Feb 15, 2010 08:57 PM
Mr. Moose
Sep 20, 2008 02:29 PM
